Question about Pyle PLMR18 Marine AM/FM Player/Radio with SD/USB AUX
Wiring how to wire into a Pyle PLMRCW3 stereo housing unit. radio has two more wires than are needed to connect to the housing unit
2 Suggested Answers
Daveatwhips
  • 492 Answers
SOURCE: I am installing a Pyle
OK, time to go into cheat mode. You can always install a toggle switch to that wire. The only features I see you losing are that the time will be incorrect on the clock and it might not save your preset radio stations. All other functions are basic. Might I suggest a lighted toggle switch, this will help to remind you to turn it off.
Happy Wiring
Posted on Aug 14, 2011
How to install Pyle radio PLR31MP
remove factory radio ,if you dont have the special tool to do this you can use coat hangers but I perfer using the factory tool sold at wallmart (the cheepest) or autozone push tools into holes on both ends of radio pull radio out. disconect wireing harnes and antenna wire.To install new radio you will need a wireing adaptor and a install kit. These must be spasific to your vehicle. you can buy these online Ebay , or Amazon or off line wallmart or orillys auto parts you will have to connect your new radio wiring harness to wiring adaptor.put install kit on new radio attach antenna wire connect wireing adaptor to original radio wiring push radio gently back into dash with install kit attached. enjoy your new radio. if this was helpful please leave good feed back.
Jan 03, 2015 | 1998 Ford Ranger
1996 Ford Thunderbird Stereo deck installation issues. I purchased a Pyle Deck and the wiring from the stock stereo has no instructions to crimp which wires to which. The Pyle deck has the instructions on...
Your best would be to buy a harness adapter to connect the new deck through the adapter into the existing OEM wire harness connector. It makes things so much easier and more reliable.
Oct 19, 2013 | Pyle Car Audio & Video
Install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Dec 04, 2012 | Pyle Plr34m In Dash Usb Sd Aux Am Fm Car...
I am installing a Pyle PLMR87WB stereo into a Pyle PLMRCW3 Water resistant stereo housing. I am soldering the connectors and shrink wrapping them. Do I need to connect the memory wire. I do not want to run...
Happy Wiring
Aug 13, 2011 | Pyle Car Audio & Video
I need the radio operating manual for a Jeep Patriot 2009 model. Where can I down load it from as the local dealer cannot seem to find a hard copy for me.
following is the procedure. u can also check ehow for more details.
  • Twist the negative cable off the terminal on the vehicle battery, using an adjustable wrench.
  • Remove the factory issue stereo. Pry off the radio trim bezel with a flat head screwdriver. Remove the four bolts on each corner of the radio. Pull the radio out the dashboard. Unplug the thick black radio antenna cable. Disconnect the wire harnesses from the rear of the stereo. Place the old stereo to one side.
  • Prepare the dashboard for the new stereo. Fit the radio installation sleeve provided with the aftermarket stereo to the radio installation kit. Feed the sleeve through the portal of the radio installation kit and bend the tabs on the sides of the sleeve to secure it in place. Feed the audio wiring of the Jeep and the radio antenna cable through the portal of the assembly and slide the assembly into the dashboard. Secure it in place with the bolts removed earlier.
  • Wire the new stereo. Connect the wiring of the stereo to the audio wiring of the Patriot, using a custom wire harness adapter. Push the connections together until they snap into place and test the connection by tugging gently on either end.
  • Plug the radio antenna cable into the alloted port on the rear of the aftermarket head unit.
  • Slide the connected aftermarket stereo into the prepared housing in the Patriot's dashboard. Click it into place in the radio installation sleeve, taking care not to trap any wiring.
  • Jan 03, 2011 | 2009 Jeep Patriot
    How do i install the visors in my dodge stratus 2000 SE 2.0, and where exactly do i connect the power cords to to get the power to get them to work, and how do i connect them to my car video stereo ? if u...
    connect the red wire to the red/white wire here is the wiring diagram
    2000 Dodge Stratus Car Radio Stereo Audio Wiring Diagram
    Car Radio Battery Constant 12v+ Wire: Pink/Yellow
    Car Radio Accessory Switched 12v+ Wire: Red/White
    Car Radio Ground Wire: Chassis
    Car Radio Illumination Wire: Orange/Brown
    Car Stereo Dimmer Wire: Black/Light Blue
    Car Stereo Antenna Trigger: Orange/Red
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Dark Green
    Left Front Speaker Negative Wire (-): Brown/Red
    Right Front Speaker Positive Wire (+): Violet
    Right Front Speaker Negative Wire (-): Dark Blue/Red
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Brown/Yellow
    Left Rear Speaker Negative Wire (-): Brown/Light Blue
    Right Rear Speaker Positive Wire (+): Dark Blue/White
    Right Rear Speaker Negative Wire (-): Dark Blue/Orange
    pls rate
    Aug 17, 2010 | Pyle PLVSR72GR Sun Visor Monitor
    I have Pyle PLTDN71, everything is wired properly , but it only plays music for 3 secs and cuts off. The problem is repeated everytime the unit or car is restarted... anyone ???
    u probably connected ur power or constant to ur lights. if ur lights turn on ur accesry switch and than ur ight if ur stereo turns off thanu have tosee witch wire is connected wrong
    Jul 09, 2009 | Pyle PLTDN71 Car Video Player
    I Need the Wiring guide
    1992 Saturn SL2 Car Stereo Radio Wiring Diagram
    Car Radio Constant 12V+ Wire: Orange
    Car Radio Ignition Switched 12V+ Wire: Yellow
    Car Radio Ground Wire: Black
    Car Stereo Illumination Wire: Gray
    Car Stereo Dimmer Wire: Brown
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amplifier Trigger Wire: N/A
    Front Speakers Size: 6 1/2′
    Front Speakers Location: Doors
    Left Front Speaker Wire (+): Tan
    Left Front Speaker Wire (-): Gray
    Right Front Speaker Wire (+): Light Green
    Right Front Speaker Wire (-): Dark Green
    Rear Speakers Size: 6 1/2′
    Rear Speakers Location: Rear Deck
    Left Rear Speaker Wire (+): Brown
    Left Rear Speaker Wire (-): Yellow
    Right Rear Speaker Wire (+): Dark Blue
    Right Rear Speaker Wire (-): Light Blue
    May 21, 2009 | 1992 Saturn SL2
    Subwoofer istalation into a clarion DXZ375MP stereo
    The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
    I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
    Mar 11, 2009 | Clarion DXZ375MP CD Player
    Wiring troubleshoot
    Make sure that your car is not amplified!! Some Celicas have an amplifier under the passenger seat. If this is the case, you will need to either bypass that amplifier and go directly to speakers, or you'll need the proper interface plug. The extra rapid heat build-up indicates that your radio is incorrectly wired (channels are mixed up)
    Your Pyle radio may have an extra wire for "amplifier turn-on" or for "mute". A standard wiring harness for Toyota (Scosche part TA-02B) should work in dash behind the radio in non-amplified vehicles. If you are still having difficulty, please seek advice from a local stereo installation shop.
    Aug 10, 2008 | Car Audio & Video
    Pyle PLMR18 Marine AM/FM Player/Radio with SD/USB AUX Logo
    29 people viewed this question
    Top Pyle Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Michial Gueffroy
    Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
