Where is the exact location of phzone7 phil
Show me the exact map
What number fuse for brake lights for 2001 ford ranger edge?
When you open the fuse panel there should be a fuse location map on the backside of the cover. The map shows the location and what system(s) the fuse protects. Find the one for your brake lights. Pull the fuse and replace it with the *exact* same amperage rating as specified on the location map (just in case it was replaced with an incorrect amp rating). There are two fuse panels in most cars. One is inside the vehicle usually located under the dash. These fuses are typically low amperage fuses. The second fuse/relay panel is located in the engine compartment. These are high amp fuses for things like the A/C compressor clutch, Anti-Lock brakes, fuel pump and other high draw systems. Check both places.
Jun 24, 2014 | Ford Ranger Cars & Trucks
How to replace a pvc valve on a 2001 buick lasabre
Phil the PVC valve is going into the valve cover and only has a rubber hose that leads back to the intake. Why do you think it needs messed with?
Jun 10, 2014 | Vehicle Parts & Accessories
Where is the map sensor located on a 1.9 litre vw jetta?
For exact location and replacing procedure of VW jetta MAP sensor,click the link below and follow the details with diagrams:-----Where is MAP Sensor Located on VW Jetta http://technoanswers.blogspot.com/2012/11/where-is-map-sensor-located-on-vw-jetta.html
---------These will help.Thanks.
Nov 25, 2012 | Cars & Trucks
HOW DO YOU CONTINUE ON A SAVED ROUTE AFTER YOU HAVE MADE THE FIRST STOP? I WENT BACK TO THE ROUTE AND STARTED IT AGAIN BUT WHEN I PROCEEDED, IT JUST TOOK ME IN A CIRCLE BACK TO WHERE I JUST WAS. ALSO,...
When you reach the first stop on a saved route the satnav should automatically set the next stop as it's destination. If it doesn't it's possible that the spot you saved as your first stop was not exactly right i.e. you didn't drive to where it's marked on the satnav. If this is the case you need to mark the spot by driving to it and pressing the car (which shows your location on the satnav) and this gives you an option to save present location. Save it and use it instead of the one you entered by address. Then when you're setting your route you'll find it in your favourites and add it from there.
To get back to the map go back to the screen which shows WHERE TO and VIEW MAP. Press VIEW MAP and it will bring you back to your map and should continue with your route.
Aug 01, 2011 | Garmin nuvi 1490T GPS Receiver
FS5500, electric clutch spins when engaged breaking wires
Not sure of exact clutch retaining method in this model but most clutches are located in position by a pin or a plate bolted or welded under the chassis. Have a close look as the locater has probably broken off. Regards Phil
Apr 17, 2011 | Craftsman Garden
We need a phil and teds repairer in nsw. we live in ermington. thanks
Karlisles if there's a repairer closer they'll tell you.
Workshop:
2 Haran Street,
Mascot, NSW 2020
Australia
(see map below)
Postal Address:
PO Box 7250
Alexandria, NSW 2015
Australia
Calls within Australia:
Ph: 1300 308 435
Fax: (02) 9700-9951
International calls:
International Phone +61 2 9700 9759
International Fax +61 2 9700 9951
Email info@karlisles.com.au
Nov 15, 2010 | phil & teds Vibe Stroller
Engine code P0107 97 Volvo 850glt hot to fix, what is it
It's the map sensor ( manifold absolute pressure) I don't have my manual at the moment, so I can't tell you exactly where it is. There should be an emissions sticker under the hood somewhere showing the location of it.
Aug 12, 2010 | 1997 Volvo 850
Tom Tom XL shows me 200-300 yards from my actual
1- Signal strenght loss is a common problem, has to do with how often they refresh, whats on your dash and how good the line of sight is to the gps sattelites. Ironically the window mount that they give you can in some cases place the gps unit too far back from the window to get good clear reception.
2- You are out in the field because of the maps that you are using. Maps while mostly accurate are not exact and road changes that are made to sections of road may take years to show up in the map or might never show up. There are only two or three actual companies that do the gps survey work for the roads, and gps manufacturers like Tom Tom buy user rights to use these maps, so if a particular section of road has changed or been moved and nobody has been out to recalcute the changes then your gps will be off the mark.
Hope this information helps you out.
Jan 14, 2010 | Tomtom One XL GPS Receiver
Home location keeps showing a different location. reloaded home address still showing a different location.
On the TomTom One, this is impossible unless you have several maps.
Each time you switch to another Map, the preferences such as Favorites and Home addresses only apply to that specific map.
Let me know if it helps or let me know exactly what you are doing to change and set your Home address.
(hint: Change preferences -> Change Home location ?)
Jan 06, 2010 | Tomtom ONE XL GPS
Wrong location on maps
Download the GPS tracker app, and your location will be A LOT more accurate.
the same thing happened to me before I downloaded the app, and now It shows my exact location 98% of the time.
Jan 25, 2009 | HTC G1
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
