Question about Amigo TRAVELMATE Mobility Scooter ()
How to change a travelmate 3 to left handed control
My right wrist is fused causing control difficulties.
  • 53 Answers
I think you mean forward using left hand, reverse using right hand, if so there should be 1 red and 1 black wire from the motor going to the motor controller if you switch these wires then your throttle should work the way you want but unless there is a speed control pot on the throttle enclosure you may also now run faster in reverse than forward
Posted on Mar 16, 2015
Location of fuse to control side mirrors on 2009 97x
Fuse panel in end of fascia
No. Amp. Function
1 15 Steering wheel lock
2 5 Steering column unit; ignition switch
3 10 Hands-free; cabin CD changer; SID
4 10 Main instrument unit; manual climate control;
automatic climate control (ACC)
5 7.5 Control module in front doors; Park Brake Shift Lock
(automatic transmission)
6 7.5 Brake light switch
7 20 Fascia fuse panel; fuel filler door
8 30 Control module in passenger front door
9 10 Fascia fuse panel
10 30 Trailer socket; electrical socket in storage compartment
between seats
11 15 Data link connection (diagnostics)
12 15 Interior lighting incl. glove compartment
13 30 Accessories
14 20 Radio, sound system I; control panel,
Infotainment System
15 30 Control module in driver's door
16 - -
17 - -
18 7.5 Manual climate control; fan
19 - -
20 7.5 Headlight levelling switch
21 7.5 Hands-free; brake light switch; manual climate
control; clutch pedal switch
22 30 Cigarette lighter
23 40 Cabin fan
24 7.5 Airbag control module
25 - -
26 5 Yaw sensor (cars with ESP)
27 - -
Trunk fuse panel, left-hand side
No. Amp. Function
1-5 MAXI -
6 30 Control module in left rear door
7 30 Control module in right rear door
8 20 Trailer
9 - -
10 30 Left-hand brake light; rear right turn signal; right tail
light; right reversing light; high-mounted brake light;
trailer lights
11 - -
12 - -
13 - -
14 - -
15 15 Seat heating, left seat
16 15 Seat heating, right seat
17 7.5 Autodimming rearview mirror; rain sensor; tire
pressure monitoring
18 15 Sunroof
19 7.5 Telematics (OnStar)
20 7.5 DVD player (navigation system)
21 7.5 Saab Parking Assistance (SPA); control module in
rear doors
22 30 Amplifier, sound system III
23 - -
24 10 Movement sensor; CD changer in trunk (accessory)
25 30 Electrically adjustable driver's seat with memory
26 30 Right-hand stop light; rear left turn signal; left tail
light; rear fog light; left reversing light; license plate
lighting; trunk lighting; trailer lights
27 - -
28 - -
29 - -
Fuse panel in front of battery
No. Amp. Function
1 60
MAXI
Secondary air injection pump (certain models)
2 20 Fuel pump; preheated oxygen sensors (lambda
probe)
3 10 A/C compressor
4 30 Main relay
Relays
1 Secondary air injection pump
2 A/C-compressor
3 Preheated oxygen sensors (lambda probe)
4 Main relay, engine (ECM/EVAP/injectors)
Sep 13, 2012 | 2006 Saab 9-7X
Showing ee in the diastolic section, therefore its not taking the b/p
There are 3 things can cause the EE error code.
1. Cuff was placed incorrectly. Wrap cuff snugly around your wrist 1" above the heel of your left hand.
2. Moving or talking during measurement. Measure again keeping your wrist steady during measurement.
3. Shaking of the wrist with the cuff on. Solution is the same as # 2.
If you continue to have a problem with the cuff, contact HoMedics Customer Support 1-800-466-3342.
I hope this info was helpful and thanks for choosing FixYa.
Sep 15, 2011 | Walgreens By HoMedics Automatic Wrist...
I 'm facing difficulty in adjusting the alarm with
from the time mode of the digital, just press the mode button until it reaches the alarm mode or sometimes it shows "12:00" then press and hold the lower left button to set, the digits blinks then the upper right button is to adjust, the lowerleft button is to choose what are you going to change. press the set button when your done. i hope i had been helped you.
Aug 10, 2011 | Timex Expedition 84601 Wristwatch
I am left handed and am experiencing difficulties scrolling with mouse
Open "Control Panel".
Open "Mouse".
Switch the mouse from "right-handed" to "left-handed",
i.e., make the RIGHT button (not the LEFT) to function as the FIRST mouse-button.
Sep 22, 2010 | Logitech Deluxe 650 Keyboard, Mouse
2004 VW GOlf 4door windows wont open,doors wont lock,trunk wont lock, what can cause this to happen all at once?
All these components operate via the central locking control unit. Check fuses No.4, 37, 6, 3, 14. If these fuses are ok, the control unit may be faulty and need to be replaced. The control unit is located behind the right dash panel.[on right hand drive vehicle , may be else where on left hand drive vehicle.
Jun 05, 2010 | 2004 Volkswagen Golf
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
Tag Carrera Twin time , second hour hand is not staying at time
The second time zone hand is running on a 24 hour face (right hand half of face is morning, left hand half of face is afternoon/evening) so all you need do is multiply what it points at by two. As an example, if your second time zone hand is pointing to the right (3 o'clock) then it represents 6am and if it is pointing to the left (9 o'clock) then it represents 6pm [9 x 2 = 18:00]
Apr 08, 2009 | Tag Heuer Link Automatic Chronometer...
Setting wrist remote controller
Follow the link below and follow the instructions for finding your watch module, once this is done you should be able to download your particular watch manual. Good Luck!
http://world.casio.com/wat/download/en/manual/
Feb 09, 2008 | Casio Technowear CMD30B1T Wrist Watch
Amigo TRAVELMATE Mobility Scooter () Logo
83 people viewed this question
Top Amigo Health & Beauty Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
