Question about Metz 45 CL-1 Flash
Sir I have a nikon D60 Camera and I want to use my METZ 45CL-1 Flash with a wireless flash trigger,I am a wedding photographer does it work fast,is it safe fore the camera,please let ,me know which wi
I have a NIKON D60 CAMERA do METZ 45CL-1 WORK WITH A wireless flash trigger,which wireless flash trigger,how to connect it
  • 20 Answers
Using a remote trigger designed for digital cameras makes it safe to use with your D60 as the trigger unit applaied to D60 will be a low voltage.
Most remote triggers should withstand the Metz trigger voltage, although there might be some that wont. You could always add a safety adapter between flash and trigger, but it is unlikely to be needed to protect the trigger.
Directly off your camera the voltage from the Flash is higher than that allowed by Canon, so it could damage your D60 unless you add a safety adapter in between. The adapters are available from wein and other vendors.
Posted on Jan 08, 2015
  • 210 Answers
Yes it works , and the speed is adjustable , as for safe contact canon and metz for safety information...
Posted on Mar 29, 2014
  • 216 Answers
SOURCE: mating Metz 60CT4 to Nikon D80 camera
The 60CT-4 was not made for digital cameras.
It does TTL on film not on CMOS or CCD sensor.
Alexander
atdlee@netzero.com
Posted on Dec 14, 2007
SOURCE: Metz 45CL-4 Service Manual wanted..
Hi !
Here is a link to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will be to some help.
Regards Lars
Posted on Feb 27, 2009
  • 124 Answers
SOURCE: Metz 58 AF with Nikon d90 wont flash
Hi, Bad news for you.
Try this.
  1. put new batteries in flash.
  2. turn flash on off camera.
  3. listen for capacitor to squeal (high pitched whistle). If you hear it it is charging. If not capacitor is bad.
  4. Also should see flash ready light come on. If it does not same as #3 above.
  5. If you pass #3 & 4# above press manual flash/check/test button on flash. No flash means bulb is out. It can be replaced.
Hope this fixed ya. Please rate. Good Luck! Comment back if you need further assistance.
Posted on Mar 14, 2009
  • 22 Answers
SOURCE: Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
Posted on Aug 20, 2009
SOURCE: Metz 45 CL Flash to use with Nikon D90
Metz in Germany advises Models CT45-1 with Serial No's 53400 or less have High Voltage triggers and must not be used on NIKON Digital Cameras Models D70 ,D80, D90 etc.and will damage Flash and even Cameras. according to a email received today. 21/09/2009 Models CT45-4 and 45CL -4 ore ok.
Michael T
Posted on Sep 21, 2009
Can metz 45CL-1 support Nikon D5100?
To use Metz 45CL-1 with Nikon D5100, you need use in apperture priority mode (A), adjust same ISO and apperture in Flash and Camera (Ex: ISO400 and F: 5.6) . The flash adjust light intensity to mantain correct exposition. You need use an adapter to conect Sync cable in your camera.
Nov 13, 2015 | Nikon D5100 Digital SLR Camera With...
How to set metz 50 AF-1 flash off camera TTL to Nikon D800
There are many solutions, here is an example:
http://www.pocketwizard.com/products/cable_accessory/flash_sync_cables/
Mar 27, 2014 | Metz Cameras
Is the nikon d60 compatiable with a metz 45 ct4
Will a Metz 45 CL 4 FLASH a SCA 346/2 AFR module work onTTL mode for a Nikon D 70 & D 40X DSLR cameras
Dec 02, 2010 | Nikon Speedlight SB-80DX TTL Flash
Metz 45 cl-1 speed light & nikon d60
If the shoe of the flash is compatible with the hot shoe of the camera then yes go for it. Should the flash shoe be different then the flash will still work but with a shoe adapter. Both are TTL so I see no reasons why they won't work. I do know of a friend who uses the Nikon with the same flash but it has the battery pack fitting and uses an adapter on the camera's hot shoe. He does weddings galore and never had a problem even though he carries a spare he has never used it.
Apr 22, 2010 | Nikon Speedlight SB-80DX TTL Flash
Can a Metz 45CL 5 be used with a CanonD40 safely?
Are you sure that you have a 45CL-5? It's a model which I've never seen nor heard of before, but it's possible that it is a non-standard custom model number for a specific supplier or territory.
The answer to your question is "possibly": but you asked if it can be used safely so the answer must be a firm "no".
Various sources (e.g. here) quote the trigger voltage on the (presumably closely related 45CL-4) to be a little higher or even vastly higher than Canon's 6v limit. Metz themselves are unclear on the issue and it doesn't help that they do not list the CL-5 on their support page nor on their main corporate page, but they do list a 45CL-4 and a 45CL-4 Digital. The differences between the two models may just be to add additional capabilities which suit digital SLR's but perhaps it also brings the trigger voltage below Canon's 6v limit.
As there is so little published information about the 45CL-5 then I strongly suggest that you do not risk your camera until you have a definitive answer from Metz themselves: you can contact their support service by clicking here. The link is for the UK, if you're elsewhere (Australia?) then you may need to make your own search.
I hope that I've been of some assistance and that the links provided help you to get the answer straight from the horse's mouth. Please take a moment to rate my answer.
Feb 20, 2010 | Metz 45 CL-1 Flash
Michael T
Mar 20, 2009 | Metz 45 CL-1 Flash
Jan 26, 2009 | Metz 45 CL-1 Flash
Contacts voltage
Originally the 45CT1 had high trigger voltage. In the production period Metz improved it to a much lower voltage release circuit. Metz homepage (metz.de) holds the information, from which serial number on have 45-CT1s low trigger voltage. However, even the high trigger voltage was lower than 200 volts, thus safe for your Fuji.
Laszlo
May 03, 2008 | Metz 45 CL-1 Flash
Metz 45cl
I found th answer in the manuel. You can not use flash when pluged into charger.
Apr 24, 2008 | Metz 45 CL-1 Flash
Metz 45 CL-1 Flash Logo
165 people viewed this question
Top Metz Cameras Experts
bhargav
TimHu
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
