Question about Sub-Zero 690 Side by Side Refrigerator
Back wall of my sub zero refrigerator ices up
...even though I've turned the temp to the lowest setting. The rest of the refrigerator operates fine.
  • 520 Answers
This is an issue that is most common in humid places. It is a good idea to run the settings at the manufactures suggested setting. this gives you the most energy efficiency. The icing problem is due to excess moisture in the atmosphere that enters the refrigerator when it is opened or the gasket is worn. You will need to manually defrost the unit by un-plugging it for about two hours about once every two months. this in conjunction with its own defrost will take care of the additional ice.
If it re-ices very fast like in just a few days or a week then it may not be running its own defrost and you will need to have it serviced. The technician will most likely replace the defrost timer or ( clix-on bulb )
Posted on Jun 15, 2009
Refrigerator not cooling top shelf
it sounds as though you have a fridge that is low on freon. If the ice is appearing mostly to the left, then thats surely your problem. if it goes all the way across, you may have a bad evaporater fan motor, fan motor switch, bad cold control, or just a door that isn't closing or sealing properly. If its the ice mostly to the left side, it probably means your evaporater is leaking the freon. I am assuming you have a model that has a cold control on the back wall, not the electronic display by your description. If your unit is less than 12 years old by the installation date, the part will still be under warranty (sub zero has an unmatched 12 year sealed system parts warranty) but the labor and freon will not be. The repalcement of that evaporater in my area usually runs about $450 with labor, freon and trip all together. It is a repair you cannot do unless you have an acetlyn torch and some silver-soldering/ brazing ability. If your model is in fact the newer style with the electronic temp display, call sub zero up (the # is on the model/serial tag in the door jamb) and tell them wahts going on. If it is in fact an evaporater leaking on this style, they will most likely pay the bill for you even if its well out of the 5 year full warranty. If you want to know for sure, remove all the shelves, then remove the cover over the lights. Then if its electronic remove the 3 screws holding the top of the back panel and tilt the panel out to you and pull it up and out: if its a dial type, remove the 2 screws holding the fan cover and then tilt the back wall out to you and lift it up and outwards, but not too far as it wil pull the wires of that control knob (cold Control) Look at the coils back there and see if the coils are frosty. If they are only frosty on the upper left of the coil, its low on freon and needs an evaporater. if its frosty all the way across, top to bottom, you need a cold control, or possibly a fan or fan switch. Hopefuly you can wade through all this. Just post back if you have any questions. Good Luck!
Aug 13, 2007 | Sub-Zero 632 / S
Our sub-zero refrigerator has not been cooling properly and mold builds up near the bottom
My Sub Zero 561 would lose cooling in the main fridge area over time and I would usually turn the thermostat down. This helped but I'd get an ice buildup on the back wall of the fridge, especially if it was packed full of stuff and didn't allow for air movement. I finally removed everything, removed the back panel to the fridge, and discovered that the entire rear area was a solid block of ice. A defrost fixed it but I had to turn up the thermostat to keep it from coming back. Now it works great after driving me crazy for years.
Jun 02, 2012 | Sub-Zero 561 / F
Rla50 fridge ices up
You may have the settings incorrect. I would try the middle setting to set if that would be better. Here is the manual:
http://kitchen.manualsonline.com/manuals/mfg/hotpoint/rla50.html?idRes=599970
May 06, 2012 | Hotpoint RLA50 Refrigerator
Subzero 632/s won't cool also frost build up in fridge
you have a leak in the evapator you will have to call a subzero tech to get it changed..
May 03, 2009 | Sub-Zero 632 / S
Sub zero 690 ice maker
also discovered if ice box auger not engaged exactly right with auger drive motor, then ice box won't be able to be pushed back the last half inch to engage the secret "turn on the ice maker" switches. Juice storage brackets also won't engage since ice bucket not flush with front of cover.
Jul 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Sub-Zero 650 / O Bottom Freezer...
The refrigerator temp keeps going up even though there isn't much in the unit
  • possible causes:
Jul 05, 2008 | Sub-Zero Refrigerators
Sub Zero refrigerator
Its trying to tell you to call someone to clean the condensor.....nice feature! Sub-zero refrigs are very sensitive and will run too much and even possibly start icing in Refrig compartment.
Oct 09, 2007 | Refrigerators
Sub-Zero 690 Side by Side Refrigerator Logo
197 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
