LOOKING FOR 64PIN MALE(FUJITSU FLM GEAR) TO 64PIN FEMALE(STRAIGHT) AMP CABLES
  • 132 Answers
Try Digikey.com
Posted on Oct 18, 2009
What should I do to make f-pin coax coupler I bought (to link two coax cables to extend the range of my cable box) receive and display cable programs?
Female to female couplers will only connect to a male plug either side. If the two plugs are female you won't be able to do it, till you either change to two males or get a male to male coupler!
Sep 21, 2013 | Cable Wholesale F-Pin Coax Coupler, 1GHz...
Where can u buy it?
Just copy this into Google "3.5mm Female to Male RCA Mono Jack Plug" That should bring all sorts of other suppliers up. It doesn't have to be made Cables Unlimited to work.
Jul 17, 2013 | Cables Unlimited AUD-4610 3.5mm Female to...
I'm replacing a missing tailgate on my 96 Ford F250 and I need directions on how to install it.
This one is simple! It is just as simple as it is to steal one too! Step 1 locate on both sides of truck bed for two round knob looking things,kinda has a flat spot in middle,male ended. Second step, On tailgate bottom corners there's a flat female slot. insert female slot over male flat rounded knob and flip tailgate to close then carefully open tailgate again and attach the safety cables on both sides.Wa La it's installed!
Sep 20, 2011 | Ford F-250 Cars & Trucks
My Toshiba Dynadock DVI has been causing all sorts of problems lately. These include: Blue Error Screens Graphic Driver crashes Display going black while plugged in Reduced GPU...
NO FUN!
I suspect your power supply MAY be your problem? As supplies age the capacitors inside begin to filter the DC poorly! Stray AC voltage (or AC content from your supply) will/can drive your components inside your Dock crazy with AC hum as false data?
Looking at the photos for your Dock I see your provided power supply does not look too beefy for all it must support? TEST with another well filtered supply...
Next check the PINS INSIDE your male connectors! Make sure none are pushed into it's body ~ below it's mates?
Also check the FEMALE connectors too ~ looking for broken MALE pins still inside the female connector bodies?
Finally try new cables?
Hope this helps!
Anthony
See this link:
File 9 pin sub connector male closeup jpg
Nov 25, 2017 | Toshiba Dynadock Port Replicator, Docking...
Trying to figure out how to connect VCR to laptop ie cables etc Want to transfer tapes to DVD
This will depend on what the connections are on the laptop. All you need is a video in and two audio (left & right) in connectors. If these are 3.5mm jacks sockets on the laptop. Then all you need is convertor cables. It will be easy if the VCR has a scart socket. As you can get a scart plug that has RCA plugs on the other end for audio and video out. All you need then is 3.5mm to female RCA plug lead(s) or if you can only get them with male RCA plugs, 3 inline connectors.
You can also get a USB to RCA plugs. See image below.
images below as well: of 3.5mm cable with RCA (male) and the female version and couplers for the males, plus the scart lead (yellow RCA is video) (all cables can be get from Amazon)
Jun 04, 2010 | Emerson Televison & Video
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
May 14, 2010 | Computers & Internet
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Cable called ?
if your looking for a 3.5mm male to male audio cable you can get them at any electronics store or at walmart heres the link to it here or for the extension audio cable the 3.5mm male to female here they are usually $10 each in the store at walmart
Aug 04, 2009 | Logitech V10 Computer Speakers
How to hook up a sound system
Go to Radio Shack. Find the phono adapter and cable section of the store. The adapter you want has a one eighth inch male plug on one end, and a set of female phono plugs on the other. Insert the male end of the adapter into the stereo headphone jack on the side of your television. Run a set of phono cables from the adapter to your receiver. Turn the volume of your television up to the maximum (100.) You should be able to switch between the different surround settings in your menu.
Jan 06, 2009 | Polaroid FLM-4234BH 42 in. LCD HDTV
How to connect 2 Amps for my car audio system
Based on your post, you actually have 2 concerns:
1. Power - Normally this is the +12V straight from the battery + terminal. If the existing power wire from the battery to your old amplifier is capable of carrying the combined current (in Amps) of the current + the new, then it is simply running an extension of the B+ line (usually big red wire) from the old amp to the new amp. The negative/ground is simply connecting to the chassis/exposed metal part of the vehicle.
On the other hand, if the old amplifier uses a rather not so big wire to supply it from the battery, you are better running another bigger wire from the same battery terminal to the new amplifier.
You have to check how much current the amp will draw from the battery and select a wire that is capable of carrying that much current without heating up. Offhand a #8 AWG would suffice for most single amp.
2. "Where does the Line cables go?" If you are referring to the Line INputs of your new amp, they maybe connected to the RCA OUTput (line level) of the old amp (it it's got one). Alternately, if the old amp has only INputs and your new amp has both INputs and OUTputs, remove the RCA connection to the old amp and plug them in to the new amp. Thereafter connect another pair of RCA male cables from the output of the new amp to the inputs of the old amp.
If neither of the new or the old amps has an OUTput RCA female, you may need to use a splitter of some sort. Below is an image of a two female RCA to a single RCA male.
You can hook it up in many ways. The simplest would be to remove your existing RCA connection to the old amp, plug in the double female/1male to the INput of your old amp. Connect the cable from the head unit to one of the female RCA. Connect another pair to the other female and the other end to the input of the new amp.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 22, 2007 | Car Audio & Video
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
