Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water dispenser cavitates when filter is installed in the water dispenser, why
No Water going in to the fridge
Hi Norm,
Most fridges don't need a motor to run in order to dispense water. A simple on / off solenoid on the water line (same for the ice maker) that makes a click when changing from off to on and on to off is usually all anyone hears (the ice maker makes rumbling sounds and you can hear ice falling into the bin - too).
Check for ice. If it has a maker and it is making ice, the problem could be a defective water dispenser switch, solenoid or other circuit component or wire. If no ice, I'd suspect a filter or water supply issue.
Make sure the filter is fully inserted and twisted into place. Many filters have marks to align when 1) inserting and 2) to let you know when it is installed correctly. When sure it is installed correctly - try to dispense water again. Many fridges will dispense water without a filter. Check your manual before trying this though! If not working still, remove the filter and try to dispense water. If you're able to dispense water, the problem is either the installation of the filter or the filter itself. Try to re-install it correctly. Try to dispense water again.
If it still doesn't work - call the plumber back and ask why there's no water. Or - try this yourself:
Locate the point of attachment to the domestic water supply that the plumber used. There should be a valve to turn the water on and off. If off, turn ON. Try to dispense water again.
If that doesn't work - check to see if the fridge has pinched, kinked or crushed the water supply line. You may need to move the fridge forward to gain access to the water line and connection point on the fridge. Repair or replace the line as needed and route in such a way that moving the fridge in or out will not cause it to damage the line again.
Nov 06, 2015 | Refrigerators
Jen Air Refrigerator (JCD2290HEW) developed problem with having low water flow at water dispenser and water hammer after changing water filter and depressing water dispenser to remove air. Have changed the...
I understand the correct manufacturers number for the PuriClean II water filter for your refrigerator should be UKF8001 or UKF8001AXX, that you have the correct filter, and you have plenty of water out of the dispenser when the filter is not installed. If all that information is accurate you have 30 pounds or more water pressure (although the minimum is 20 pounds the higher the pressure the better for flow will be), then I would try holding the filter under the faucet to be certain the water flows through the filter without a lot of resistance. If that checks out, I would look for a gasket or some other part from the old filter that is stuck in the filter housing.
Nov 03, 2013 | Jenn-Air Refrigerators
No water coming out of the dispenser
Hello there and welcome to fixya
Dispenser Does Not Operate
  • 1 Ensure that the water supply line is installed according to the manufacturer's directions. Turn the water supply shutoff valve counter-clockwise to fully open it.
  • 2 Replace the water filter or remove the filter and install the plug. A clogged filter will prevent the water dispenser from functioning properly.
  • 3 Place a large container under the water dispenser. Press and hold the dispenser lever for at least two minutes to remove air in the water system.
Does Not Dispense Water
  • 1 Inspect the supply line and shutoff valve for clogs. Call a plumber to remove clogs in the line or shutoff valve.
  • 2 Replace the water filter cartridge or remove the filter and install the plug.
  • 3 Ensure that the filter cartridge is installed properly. Remove it and reinstall the filter cartridge. The cartridge will lock into place when installed correctly.
Read more: Troubleshooting GE Refrigerator Water ' eHow.com http://www.ehow.com/how_7170675_troubleshooting-ge-refrigerator-water.html#ixzz1XoEkLTk8
Sep 13, 2011 | Refrigerators
Water leaks out of the dispenser
Hi
Under some circumstances the water dispenser can leak water into the spill trap when not in use. This problem could be caused by one of several scenarios involving the installation of the refrigerator doors. Small leaks are often triggered when a new water filter is installed. The exact location of some parts will vary depending on your model of refrigerator.
Keep a glass under the dispenser for up to three seconds after releasing the lever. The water doesn't cut off immediately, and there may be a few remaining drops in the system. This is normal and doesn't need any further attention.Run the water dispenser into a large container for three minutes. Empty the contents of the container down the sink. A newly installed water filter may spurt or leak water from the dispenser until the water is run for a few minutes. Some dispensers may cut off after a few minutes automatically.
Run the dispenser intermittently -- five seconds on, five seconds off -- for two minutes. This measure clears air trapped in the supply line, filter and dispenser system. Some dispensers will spurt or leak water until all air is purged from the system. You should follow this step each time the water is disconnected or the filter changed.Ensure all components of the water supply have been properly connected. All connections should be tightly screwed in place and pipes straight so water doesn't leak out of the pipes or dispenser nozzle. Contact a technician if you didn't install the refrigerator yourself.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Refrigerators
Bought a new Maytag side by side. Will not put out water. Tried the 5 sec on and 5sec off to flush the air out, still didn't work. What next?
Hi and welcome to FixYa, I am Kelly.
First off you need to make sure the freezer door is CLOSED and water filter is properly installed in the filter housing. Without a model number I can not tell you the exact location of the filter. There is a water lock out function of the water filter housing that will prevent proper water flow until the filter is installed correctly or removed completely. Also... there is a water tank / reservoir that has to be filled completely with water before you will see any water at the spigot. Please pass your model number so I can better assist you or call the Maytag Sercive Center so they can walk you through the initial set up procedure of your refrigerator. (They will also need your model number) Go to http://www.maytag.com and register your appliance before making the call.
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Before making the call check out this information about troubleshooting:
http://maytag.custhelp.com/app/answers/detail/a_id/110/kw/Water/session/L3RpbWUvMTI5ODY4MTEyNi9zaWQvam9CYWV5bms%3D
- After connecting the refrigerator to water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue to press and release the dispenser bar (5 seconds on, 5 seconds off) until a total of 3 gal. (12 L) has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system water may spurt out of the dispenser.
- Make sure the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the Unlock or Locked button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.
- If there has been a recent power outage or the power supply has been off for more than one hour, the power outage indicator (on some models) will disable the dispenser function. The dispenser display will read "PF" to indicate power failure. To use the dispenser, press and hold the "Reset" button for 3 seconds until you hear the beeps.
-A clogged or incorrectly installed water filter will reduce the water flow to the water dispenser. Check for a problem with the filter by removing the filter and operating the dispenser. If water begins to flow, then the filter is either clogged or incorrectly installed. A clogged filter will need to be replaced.
If the filter is clogged and you are not able to immediately replace it, leave the filter out so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing. However, in order to have filtered water, you will need to install a new filter.
All Genuine Maytag Water Filters retain beneficial fluoride and are NSF Certified for drastically reducing chlorine taste and odor, particulates, lead, mercury and cysts.
To ensure glass after glass of clean, refreshing ice and water, change your filter yearly or whenever the system light indicates.
about the filter:
http://assets.whirlpool.com/files/usr/animations/ANM000085.htm
The information above should get your water working. If not please listen for a solenoid buzz as you actuate the water in door function. No buzz either the dispenser is locked off or.... you have a valid warranty claim.
Thanks for choosing FixYa,
Kelly
Feb 26, 2011 | Maytag Refrigerators
We have a Hayward Pro Series sand filter S244T. It was installed 3 years ago. There is no indication of flow through the glass bulb on the back of the valve when the valve is in normal operating...
The sightglass is designed for backwash only, it allows you to see the degree of clarity in the effluent water. There should not be flow through the sightglass when the filter is in normal operation. Sometimes the pump will be alot louder when you backwash because there is alot less back pressure and it sometimes causes pump cavitation. The pump should quiet down when in normal filter mode. If not, there may be problems with the bearings and/or cavitation.
Aug 15, 2010 | Hayward SAND FILTER, PRO SERIES
We just replaced the water filter...now dispenser doesn't work.
Looks like water is frozen in the tank .Unplug refrige from wall socket ,leave freezer and food compartment doors open at least 12 hours to melt frozen tank..
Jan 18, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Water will not flow out of dispenser
This is common when the water filter needs to be replaced. GE recommends:
Water filter clogged. Replace filter cartridge or remove filter and install plug. Air may be trapped in the line: Press the dispenser arm for at least two minutes.
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds.
The water line may be turned off or disconnected.
Sep 07, 2009 | GE Refrigerators
Water does not come out of the refrigerator door, but the ice works
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, When the water dispenser is pushed you can hear it try to work (a humming or pumping sound) but nothing comes out.
Below is a list of reasons that the water may not be working that are easily checked and remedyed by you! Is there a water shut off on your fridge?If so the dispensor will still make noise as if it is trying, even if it is locked!!!!!!!!!!!!!!!!!!!!!!!
1. When did you change the internal water filter last?
You can remove the water filter and still use the water dispenser to check if the filter may be the problem!If nothing changes reinsert the water filter.
2.Flushing the water system after replacing filter
Use a sturdy container to depress the water dispenser bar until
the water begins to flow. Flush the water system by dispensing
and discarding 2 to 3 gal. (8 to 12 L) of water. Cleaning the
system will take approximately 6 to 7 minutes and will help clear
air from the line. Additional flushing may be required in some
households.
NOTE: As air is cleared from the system, water may spurt out of
the dispenser.
3.***Read this:
The dispenser lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
accidental dispensing by small children and pets. To turn off the
dispenser, press the LOCK button. The indicator will appear
above the LOCK button and the ice and water dispensers will not
work. To unlock the dispenser, press the UNLOCK button until
the indicator appears. Then continue to dispense ice or water as
usual.
NOTE:********** The lock feature does not shut off power to the product,
to the ice maker, or to the dispenser light. It simply deactivates
the dispenser levers.
4.The water dispenser will not operate properly
 Has the water system not filled? The water system needs
to be filled the first time it is used. Use a sturdy container to
depress the water dispenser bar until the water begins to
flow. Flush the water system by dispensing and discarding
2 to 3 gal. (8 to 12 L) of water. Cleaning the system will take
approximately 6 to 7 minutes and will help clear air from the
line. Additional flushing may be required in some households.
See the “Water and Ice Dispensers” section.
 Is the water shutoff valve not turned on or the water line
connected at the source? Make sure the water shutoff valve
is turned on and the water source is connected to the
refrigerator. See the “Water Supply Connection” section.
 Is the water shutoff valve clogged or incorrectly installed?
See the “Water Supply Connection” section. If clogging or
installation is not a problem, call for service or contact a
plumber.
 Is there a kink in the home water source line? If you find or
suspect a kink in the water line, call for service.
 Is there a water filter installed on the refrigerator? The
filter may be clogged or incorrectly installed. First, check the
filter installation instructions to ensure that the filter was
installed correctly and is not clogged. If installation or
clogging is not a problem, call for service.
Please remember to leave a rating before you go!
Thank you,
Huuum
Sep 29, 2008 | Whirlpool GD2SHGX Refrigerator
Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Sep 05, 2007 | Amana ASD2326HE Side by Side Refrigerator
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
