Question about Panasonic DMC-ZS1 Digital Camera
Blurred image dropped with lens extended
How To Repair Canon IXY 810is
Could be several reasons. The front lens is dirty. That can be cleaned with a lens pen. Or a soft cloth, the same as you should use for your glasses.
It could be there is mould in the lens system. You can see this when looking into the lens, passed the front lens. That can't be fixed, without replacing the whole lens.
And when the camera is dropped on the lens, it could be the elements are not aligned anymore. Same as with mould, only an expensive repair could cure that.
I hope you did not try to clean the front lens with any fluid like alcohol, because that is irreparable to.
Nov 15, 2013 | Cameras
Lens blurred
To come closer to the colprit, if you shoot a picture and you put it on a PC (tablet) does the picture still look blurred?
If it does, the most likely is the image sensor or the lens are broke. If the picture is ok on the PC, only the display is bad.
Are you sure you don't see anything on the lens? Is perhaps a little dent on the outside visable? That could be caused by a fall with the lens outside the body.
Nov 06, 2013 | Casio EXILIM EX-Z400 Digital Camera
Images are blurred
Blurred images can have different reasons. Greasy lens, camera shake or focus error.
You can clean a greasy lens with a lens-cleaner solution and lens-paper.
Camera shake will (most likely) only occur on images taken without the flash. Most likely there will be a warning on the display if risk of shake. it's a hand with an "!". Focus error will usually also give a warning in the display.
May 09, 2010 | Fuji FinePix S2000hd Digital Camera
Dropped camera. The viewer works, the recorder works - but the picture comes out blurred. I can hear it trying to adjust itself.
Hi there the camera lens guide pin is damaged after drop down. Thats why you get a noise for focusing the lens but it did't focus. After that the result is blur image. You must change the guide pin from service center. After that it will work start properly. Thanks.70ed0c8.jpg
Mar 23, 2010 | Olympus Stylus 710 Digital Camera
PROBLEM WITH LENS/ LCD SCREEN
problem with the lens,not with the lcd,the image fomation is bad,so replace the C.C.D
Mar 05, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
Canon G7 lens get stuck with no liveview image.
ur lens belt got creck send it for replacement
Jun 17, 2009 | Canon PowerShot G7 Digital Camera
Problem with the lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 25, 2009 | Cameras
Nikon D40 will not focus
on the right side of the view finder there is a little bar. Make sure it is all the way down. If it is in the up position then it will make the viewfinder, shouldn't make the images blurry though. Also make sure it is in AF not MF (auto focus and manual focus).
Oct 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Olympus u 700
In on postion in camera mode,the lens seems to move in and out,blurring the image and then stops with this message on screen. D: 5f O8 5eO2
Jun 26, 2008 | Olympus Stylus 710 Digital Camera
Panasonic DMC-ZS1 Digital Camera Logo
21 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
