Question about Dell E151FPp 15" Flat Panel LCD Monitor
No display but power led is on
I have dell E151FPp lcd monitor .No display
Power led is on
osd is working
When i unplugd the data cable its showing no signal
  • 334 Answers
Sounds like a video card problem in your pc. If you are using the onboard video output on your motherboard, you probably need a new one. If you are using a card that has been added to the board in a slot, try your onboard output (looks the same)
Posted on Jun 15, 2009
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
How to get rid padlock Dell E176FP 17&quot; LCD Monitor Dell monitor lock display and all display button not functioning ang monitor power too
You can follow these steps:
1.Click on the menu button in front of the monitor
2. Select OSD settings
3. Select OSD lock
4. Then choose Yes or No to lock and unlock it
Hope this helps
Thanks
Dennis
Oct 26, 2011 | Dell E176FP 17" LCD Monitor
Dell E151FPp 15" TFT LCD
It does not have DVI port, only VGA.
http://support.dell.com/support/edocs/monitors/e151fpp/En/attach/attach.htm
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 17, 2010 | Dell E151FPp 15" TFT LCD Flat Panel...
Benq q5t4 monitor. power on "BENQ" display is
i want data for benq q5t4 moniter eprom 24c04 ic my moniter is not working properly
Dec 17, 2010 | BenQ FP51G 15" LCD Monitor
Power Board Dell E151FPp
Did you check the fuse PF751, it should be less than 1 Ohm?
Also look for cold solder joints.
http://s807.photobucket.com/home/budm/allalbums
Mar 23, 2010 | Dell E151FPp 15" TFT LCD Flat Panel...
No plug in play... don't think their dead... do I need drives first?
no country stated or if not usa what is your line power?(volts AC)
your PSU is inside monitor not outside, so uses a simple line power cord. (just wires)
12 year old monitors, found, (dead)
page one of your user guide is clear, read it yet?
seems not.,
Auto-ranging, 90 to 265 VAC
1280 x 1024 @ 60 Hz, 75 Hz (never higher) resolution settings.
those are very old monitors.. worth like $10 used.
if the power lamp shows wrong, the monitor is dead.
right button is power to the right of it is a power led that must glow.
the old monitors had CCFL backlamps before year 2010.
those are back lamps, that fail fast. 20k hours, fast. (short)
first is the power switch
2nd is a working PC with at least sync signals on 2 pins
Horz/vertical.
then the OSD screens work of not the monitor IS DEAD.
inside this OLD monitor is sleep time, turn if off with OSD menu's its nothing but trouble.
some have an OSD lock, so hold the menu key for 10 seconds
and it unlocks. button 2 from left is MENU.
see page 4-10
the guide is here. not too good , poor diagnosis sections
http://h10032.www1.hp.com/ctg/Manual/c00276671
specs.
https://support.hp.com/us-en/product/hp-l1940-lcd-flat-panel-monitor/427303/document/c00278650#AbT3
testing
power it on, LED power , glows.
with a PC working, say running any BIOS screen only....
or running, windows, in low resolution mode 1280 x 1024
if wise set the pc up to that first. not second.
then plug in the vga cable so the MOnitor only sees that signal above. (if you do above wrong, monitor shows OUT OF RANGE on the screen)
at mon.
PUSH the OSD button, menu, if OSD is dead the montor is dead.
OSD= on screen display., (yes the LDC has brain inside)
then take a flash light . point it at screen
see data now, if yes, in the beam is data the back lamp is dead
as are most 12 years old montors now.
see those 4 cream colored connectors bottom of this PCB
those are the high voltage CCFL lamps.
2 lamps 4 ends. the lamps are bad or the board 500 to 1000vdc
power supply is dead.
Sep 20, 2017 | HP L1940 19" LCD Monitor
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
Monitor problem
It sounds as if you have a resolution set that the display does not support. Restart your machine in safe/VGA mode by holding down F8 while the machine boots. Once in safe mode, set the resolution (Right click--> properties--> Settings--> Screen Resolution) to one that your display supports.
Jun 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E151FPp 15" Flat Panel LCD Monitor Logo
324 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
