Danby DMW139 1100 Watts Microwave Oven
Problem for Danby DMW139 1100 Watts Microwave Oven
Door won't open
By nocode76 on Oct 31, 2007
When trying to open the door by pushing on the rectagular button, there is no resistance and the mechanism inside has obviously broken. How can I open the door without causing too much damage? There's a container full of milk in there and would like to get it out before bringing the micorwave back to the store.
Same Problem
Jan 11, 2009
-   Sylvania Microwave / Convention oven, Model # Wd1000ASP28RII-6 Door won't open. Is this any different then the answer already given? -   ctisdell
Dec 19, 2007
-   Push latch and the door does not open-   Guest
Best Solution
posted on Nov 06, 2007
Helpful)
btech25
Rank: Master
Rating: 89%, 19 votes
Im sorry to say, but the housing will have to come off to unlatch the door from the inside.Not difficult ,Unplug the unit and remove all of the screws around the top of the housing cover if any,also
rear and both sides will have to come out.When they have all been removed, lift the rear of the top housing cover and pull back.You will be able to see where the two door latches are locked in place.With a screwdriver,you can push up on the bottom latch and the door will open. All this can be done without spilling the milk inside.Just slide the microwave around slowly to get to the screws.The broken part inside should be able to be replaced.Contact repair parts center.
Was this helpful?
Yes
No
Popular Solutions for Danby DMW139 1100 Watts
Questions and Unsolved Problems for Danby DMW139 1100 Watts
Do you recommend Danby DMW139 1100 Watts Microwave Oven?
Answer
Answer
light bulb burnt out. Can I replace it myself and how
Answer
microwave was bought in 2001 and has never given us a problem. I noticed yesterday when trying to... (More)
Answer
We have a built-in Danby 1000 watt microwave oven (purchased 2004, 2 speed exhaust fan, turntable... (More)
Answer
the inside light does come on and there are no unusual noises the only thing that i noticed it that... (More)
Describe your Microwave Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Oven Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
