Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
Fuel problems cleaned carb and still will only run with starting fluid
    Sergeant:
  • 462 Answers
Fuel pump not working or filter plugged
Posted on Sep 07, 2014
MK2A Ride on mower won't start
If it will fire with starter fluid, it's about 100% that you have a carb
problem. The fuel jets don't take too much to stop up.
Re-clean the carb paying close attention to any orifices.
Jan 31, 2018 | Garden
2002 ford mustang v6 set for weeks then no fuel to carberator want start without starter fluid
carberator ????? Has fuel injection , if not altered ???? Security light on steady or flashing ? Fuel injector's not firing . Fuel pump ,test fuel pressure .
Dec 03, 2017 | Ford Cars & Trucks
On this cart, I have cleaned out carb twice. Battery good. It runs shortly then dies out. Micro switchesx4 has been replaced. Spark plug good. Gas is good and getting to carb.
Determine if it is running out of fuel or no spark.
If it stalls but will run on carb spray or starting fluid
sprayed in carb opening then the fuel has problems.
If it will not run on the starting fluid then the spark is weak
or failing due to bad wiring or coils. Once you isolate
the problem to fuel or spark then you can probe those areas.
Be sure compression is good also. 100 psi at least.
Mar 09, 2015 | GAS Motorcycles
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
I have an echo shred e vac blower it won't start.i cleaned the sparkplug,tested the stop switch ok,it still will not turn over,
Do you get spark? Is fuel making it's way to the carb.? If no spark need new coil, if no fuel clean carb. and rebuild.
Nov 12, 2010 | Garden
Runs on starting fluid, not fuel. cleaned carb with carb cleaner(aerosol) ,still won't run. Primer (purge) bulb doesn't work properly. Spark plug dry, fuel lines clean. Diaphram problem or something...
Try spraying a little gas where you spray starter fluid. If it runs you may have to install diaphram kit. If it has a choke can get around primer not working.
Oct 01, 2010 | Poulan Pe550 Gas Edger
Turns over won't start. hasn't run in over a year and has had problems idling while cold. thinking carb needs cleaning... thoughts?
check and clean carb, try a lil carb fluid in carb to fire, also check the usual things for a tune up: cap & rotor, wires , also if its sat for a year add some clean fuel, condensation in fuel tanks and lines will wreak havoc, and will clog even brand new fuel filters
Apr 05, 2010 | 1987 Toyota Pickup
Engine starts easily, but doesnt stay running. removed fuel cap, still the same, pulled off fuel line, its not plugged. With the air cleaner off if I spray in starting fluid it keeps running, but will stop...
sounds like a fuel problem in the gas tank or carb. If bad gas or debris gets into the carb fuel bowl, this will fowl up or clog the jets after you start to run your engine. you need to remove your carb and clean the fuel bowl and jets. use a jet carb cleaner to do this. without knowing what type of engine, make sure all ur jets are clean. use a fine wire to insure they are clean and put te carb back together. also check and clean the fuel valve area of the carb, the fuel line, and the fuel tank. never use last years gas and always run your equipment out of gas before you store it for the winter.
Jun 07, 2009 | Craftsman Garden
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
My Coleman OHV 3000 will not start
dont use starter fluid ,will ruin engine.Sounds like the float in the carb is stuck.and keep lookin for a filter.
Dec 21, 2008 | Coleman Powermate Premium Plus 6250W...
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
74 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
