Question about Toshiba SD-2900 DVD Player
Code I need the code to program it into sony trinatron remote
Also code for sony vcr model slv-n-500
Maanita
  • 1142 Answers
SOURCE: need code
Toshiba 018,021,023,071,085,090
Posted on May 26, 2008
dvinnedge
  • 35 Answers
SOURCE: Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
Posted on Nov 29, 2008
SOURCE: Toshiba CT-877 Remote
http://remotes.com/remotes/documents/Toshiba/CT-877.pdf
Posted on Jan 19, 2009
chalio1214
SOURCE: need programing codes to run my cble, vcr, and dvd
i need the code for my toshiba ct90159
Posted on Jun 02, 2012
gopakumarg43
  • 74383 Answers
SOURCE: I need code to program a RCA412SIR remote for a toshiba MW20F52 tv/vcr/dvd combo
0261,0266,0260. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Posted on Jan 18, 2015
My Sony VCR Model SLV-662HF will not accept cassettes. I am using a universal remote control. The VCR's display shows APC 71501 and 81508. Do these APC codes refer to the VCR or the All In One universal...
The codes are to program the universal remote control to communicate with the Sony VCR. Try programming the universal remote using one of these: 60000 60032 60033 60035
The acceptance of the cassettes may not be related to the use of a universal remote control. If the URC doesn't have the "equivalent" functionality of the VCR's original remote control, you may not be able to use the URC to perform the functions of the original remote control.
Dec 13, 2013 | Sony Slv-662hf 14" Vcr Plus Rmt-v266...
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
http://www.thompsontv.com/rcarc.html
click the above link and programmed your remote control..
thanks
good luck
Oct 01, 2008 | Sony SLV-679HF VHS VCR
I have lost the remote for the SLV-SE740 model VCR. What is the model of the Sony original remote that I need ?
I've purchased the manual which should specify the associated remote.
Thanks,
Adrian
Jan 25, 2010 | Sony SLV-SE740 VHS VCR
I need the original code for my sony vcr model # slv-675hf so i can use a universal remote control
Your universal remote control should have its own list of codes for products that you want to program. Do you not have this list anymore? You should be able to locate it online. I can help you with that. What is the make and model of the remote?
Nov 13, 2009 | Sony Televison & Video
Lost codes for v.old universal remote
All universal remotes work about the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | Sony SLV-SE720 VCR
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Remote control code
That doesn't sound quite like the usual procedure for programming a universal feature on a remote. Should have to put the remote in TV mode, then press something to get it into programming mode, then put in the code for your particular TV.
Oct 17, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Toshiba SD-2900 DVD Player Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
