Question about Punch Software Interior Design Suite
Unknown return code 513
I keep getting this code after I input my key code.
Riso EZ 571A with error code T04-513 keep appearing on the screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 12, 2017 | Exercise & Fitness
Reload Software 513 in Black Berry Bold 9000 series. I forgot my password and i entered wrong password for specified number of times and now Only white screen with reload software 513 is written in the...
SIM CARD:
If you enter a wrong PIN code too many times, usually three, your SIM will lock itself. This protects you from someone using your personal information or making calls if your cell phone is lost or stolen. You may see "PIN blocked" or Enter PUK code" on your cell phone display. The PUK code stands for PIN Unblocking Key. In the U.S., the PUK code is rarely provided when you get your subscription.
If you do not have your PUK code, contact the Customer Care customer again. Give them your phone number and once they are sure it is really you, they will give you the PUK code.
You will then be asked to set a new PIN code. Once you have your PUK be sure to keep it in a safe place.
Note that if you enter a wrong PUK 10 times in a row, the SIM will be permanently blocked, and you'll need to purchase a new SIM card.
Jun 17, 2012 | RIM BlackBerry Storm 9530 Smartphone
Camshaft postion sensor went out, was replaced. crankshaft sensor also replaced, Still not starting. Suggestion?
Hi, did you get this fixed? im having the same problem. heard it can be the key itself(shim key) data code 513. if you got this fixed let me know what you did.
Dec 11, 2010 | 2004 Chrysler PT Cruiser
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
What is a P 431 and 513 Error Code on a 2005 Jeep Rubicon?
p431 = Warm up Catalyst effiiciency below threshold on Bank 2. Most likely you have an O2 sensor that has a defective heating circuit.
p513 = The engine controller has received an invalid key from the Smart Key Immobilizer Module. Unless you had or have the wrong ignition key, this one can be solved on this chat.
Sep 07, 2010 | Jeep Wrangler Cars & Trucks
My blackberry curve saying jvm error 513 reset i did but nuthing
Your blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware. Download the Blackberry Desktop manager and run the application loader.
May 13, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
My blackberry keeps saying download software 513
my blackberry says reload software 513 what site can i go on to fix my phone
Feb 20, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry pearl
Try holding these keys simultaneoulsy.
ALT+RIGHT SHIFT(CAP)+DELETE Until you get a blank screen then power on.
Failing that power off, remove your battery for 30 seconds and then power on.
Feb 08, 2009 | RIM BlackBerry Pearl 8100
Jvm eror 513
pls reset u'r phone
Aug 05, 2008 | RIM BlackBerry Pearl 8100
Error code f35 konica 7022
Turn on the main and sub power switches.
Keep pressing the
* button until the message
“Please enter service password.” appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press the key of the mode to be selected on the
screen. To return to the Mode Change Menu
Screen, keep pressing the
* button until the
screen appears.
When the adjustment ends, press
[1. Normal Mode] key and the basic screen will appear
Jul 14, 2008 | Office Equipment & Supplies
Punch Software  Interior Design Suite  Logo
Top Punch Computers & Internet Experts
k24674
Are you a Punch Computer and Internet Expert? Answer questions, earn points and help others
