Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Remote control bn59-01014a problem
Unable to control TV for a few function
Unable to get remote to recordings or menu
Hi.
the only reason why these functions are not working is because your Remote control is on TV mode. The best way to resolve it is by Pressing the ATT button on the upper left hand corner of your remote and all functions will work..
I hope this helps you and please don't forget to rate me.
Thank you.. :)
Apr 18, 2014 | AT&T UVerse
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Unable to use remote with my Bush A626 tv
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 29, 2017 | Bush Televison & Video
Program this remote to control volume on my panasonic tv
Hey teresa_ne685,
Programming the remote to a TV can definitely be done. I have provided the steps below along with a few codes. You can visit the link to look-up your model specific codes!
Link: http://www.dishnetwork.com/SupportSection/remote-setup
Codes: 765, 644, 811, 512, 700, 823
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Let me know here if you have any other questions!
Tommy Faust
DISH Network
Oct 08, 2011 | DISH Network IR Remote Control
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
We are using the RadioShack 4 in 1Family Favorites universal remote with a sylvania 6727DD TV/VCR/DVD combo unit, but we are unable to get the TV menu to open up so that we can scan and auto program the TV...
Used ur original tv remote?Try website like Remotes.com to buy an exact tv original remote.Universal remotes only can do the tv basic.Open up tv menu to do within functions within the tv,more personal complex to the individual tv itself.
Sep 30, 2010 | Radio Shack 15-2142 Remote Control
Remote Problem
Remote codes are programmed into the remote at time of and since the TV was manufactured after the remote it will be unable to have the code as TV manufacturers change codes often. You can try having a 20 or 21 remote sent to you but ensure it will work with your receiver. These remotes are programmable and ar able to learn functions of other remotes. Thanks for using Fix Ya.
Jan 31, 2010 | DISH Network IR Remote Control
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Dec 11, 2009 | Samsung Televison & Video
Tv remote needed
The most inexpensive solution, is to buy a universal remote. I own a One-for-All universal remote (model URC-4220) which works with Memorex TVs. I bought it at Walmart for less than 10 dollars.
If you want to pay a little more money, here are a few websites to visit: REMOTES.COM 1-800-REMOTES
MRREMOTECONTROLS.COM 1-800-221-1471
You can find a few more websites by typing in:
MEMOREX TV REMOTES into the Google searchbox.
Hope these suggestions help you out. Please take a moment to rate the info I have provided, but using the rating system below. Thanks.
Jul 11, 2008 | Memorex MT1194 19" TV
Hitachi TV
If your remote transmitter is multifunction, such sa TV; DVD; and VCR operative; You may be in the wrong mode. Press the TV function first and then try to change the volume. If you still have problems, the remote may be defective.
Nov 15, 2007 | Televison & Video
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
20 people viewed this question
Jerry Greenberg
Jerry Greenberg
