Question about Yamaha HTR-5830 Receiver
Cant turn on receiver
Changed batteries-manuel say that code is fixed; is the remote broken?
TX-nr1007. what are the remote codes?
Codes are stored in the remote. Yours may be incompatible with your Onkyo receiver.
Oct 24, 2015 | Onkyo Televison & Video
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
Receiver was beeping all the time. I changed batteries in receiver, and now remote does not control fireplace. Remote appears to be working fine. If I move switch to on instead of remote on receiver, it...
If you changed the batteries in the receiver (the black box in the fireplace). You should also change the 2-batteries in the hand-held remote. This may sound stupid, but it's not ... be sure all the batteries in the receiver (black box) are all facing the proper direction. Believe me, it's easy to get one turned the wrong direction. Also, make sure that the slide switch is in fact in the remote position. It can be finicky at times. Also, check to make sure that the two wires are still connected firmly at the gas fireplace Control Valve and in the receiver.
  • Now, if all of that doesn't solve your problem, the receiver may have lost it's code..
When matching security codes, be sure slide button on the receiver is in the REMOTE position; the code will NOT "LEARN" if the slide switch
is in the ON or OFF position. Program the remote receiver to LEARN a new security code by pushing in the LEARN button on the top of the
remote receiver and then pressing the MODE button on the transmitter. A change in the beeping pattern, at the receiver, indicates the
transmitter's code has been programmed into the receiver.
There's a lot to check out and do, but that's how you trouble shoot these remotes.
Feb 03, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
My remote control has broken. I am getting no response although I have changed the batteries
There are two possibilities for failure; the remote itself and the receiver in the recorder.
Many service shops have a simple device that will reveal if the remote is putting out any signal at all. If it does, the output is probably correct; they don't often fail by screwing up the coded infra-red signal.
If the remote seems to be working, then your problem lies with the receiving end inside the recorder.
Oct 24, 2009 | Evesham PVR160 Freeview 10-Hours Video...
Onkyo TX-SR702 remote problem
So what you're saying is you think the receiver is broken because the remote won't turn it on.
Try fresh batteries or another remote that can be programmed for the Onkyo and get back to us.
Apr 12, 2009 | Onkyo TX-SR702 Receiver
Can't program emerson junbo universal remote
i lost my instrution manuel for my emerson jumbo universal remote,i need the code so i could turn on the t.v off,can you please help me...
Dec 14, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Remote will not program
See this website. It worked for me and I've never soldered before.
http://mysite.verizon.net/amp68/
Sep 02, 2008 | Kenwood VR-507 Receiver
Cant find code
lock in our manuel for manuel code entry those universal remote dont alway got the code manuel code entry take some time it should work cheers
Jan 17, 2008 | GE JASRM24912 Remote Control
Yamaha HTR-5830 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
