Question about Worx Electric Blowervac With Carrying Case 644515
No suction or blowing
Motor runs, but there is no suction on vac or blowing
My very old 6 us gallon wet-dry shop vac now blows instead of sucks.
connect the hose on the other end where it say vacuum not blow.
Sep 19, 2016 | Shop Vac Vacuums
How do I get my Shop Vac to suction instead of blowing?
Unlatch and remove the cover, then reseat it and latch it to restore suction.
Feb 05, 2015 | Shop Vac Vacuums
How to replace on-off switch
Modern vac motors are polarized and cannot be made to run backwards. Take it to your local vac repair shop and let a professional repair it for you.
Jan 08, 2015 | Hoover Vacuums
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
When trying to use shop vac for suction, at the same time the space for blowing is operating. how do i stop this blowing process so i can use it as a vacuum?
On the shop vac there should be 2 places to insert the hose. One for blowing air and the other for suction.
Mar 22, 2011 | Vacuums
Pump Cycles on and off. Runs for 10 to 15 seconds then shuts off for a period and repeats the cycle.
Is this motor thermally protected? Are you running it on 240 VAC and the pump is set up for 240 VAC? (120 VAC- and 120 VAC?). Pump is on its own circuit, or one adequate to supply the proper volts, amps and watts? No extension cords involved?????????
The motor does this because it is over heating for some reason ... improper voltage comes to mind.
You say it starts but will not run ... a faulty run winding comes to mind (start circuit is evidently ok)
Overheating can als be caused by an obstruction in the suction or discharge ...
May 31, 2010 | Polaris Pb4 - 60 Booster Pump
MY SHOP VAC STOPPED WORKING AFTER USING IT FOR A WHILE
If by stopped working you mean that it no longer has any suction, then check the hose for a clog and also clean all the filters.
If you mean that it literally stopped running, then the most common cause is a faulty switch. If the machine is still under warranty, contact Shop Vac for a replacement motor, Switches for shop vacs are not available, only replacement motors. If the machine is not under warranty you can either replace the motor or the whole machine.
Oct 22, 2008 | Shop Vac Vacuums
Hoover savvy no suction on carpet setting
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Apr 29, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Worx Electric Blowervac With Carrying Case 644515 Logo
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
