Question about Kodak EasyShare DX4530 Digital Camera
Help resetting memory card
My camera keep saying memory card needs resetting I did reset it but I keep getting the same thing
  • 48 Answers
Can you check if the Write protect swith is on on the SD card. It means as I understand, you have to reset the swith to inactive state.
Posted on Nov 26, 2014
  • 60 Answers
SOURCE: memory card is in camera(kodak c613) Camera
Make sure the card is fully pushed in; otherwise it could be the reader.
You could try to insert the card into an external card reader connected to a PC.
If it is recognized by windows, click "format".
If that works put the card back into the camera.
If it is now recognized, go to "menu" and format again with the camera.
If the card is not recognized, your internal card reader seems to be faulty.
Posted on Mar 07, 2009
xscrewdriver
  • 246 Answers
SOURCE: Screen is saying Memory card is protected (reset switch on memory card) and it won't take pictures.
if you have tried to set the switch to unlocke on your SD card, and still have this problem, you may need to open your camera to check the SD card slot.
this tips might help:
http://www.myfixtips.com/blog/uncategorized/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on May 07, 2009
  • 34 Answers
SOURCE: Kodak C340 Memory card Formatting
The write protection is on the card (a little "pin").
Posted on Jun 09, 2009
  • 63 Answers
SOURCE: It says my memory card is protected
On the side of the memory card, there is a small slider that locks and protects the memory card from being overwritten. Yours may be in the locked position. Simply pull out your memory card form your camera and unlock your memory card by sliding the tab.
Hope this helps,
Andrew
Do not forget to vote.
Posted on Apr 09, 2010
  • 11967 Answers
SOURCE: When I turn my Kodak
Move the slide switch on the side of the card to "unlocked"
Posted on Aug 10, 2010
Why is my camera saying memory full when it has no pics or videos stored in it?
the card needs to be formatted either by the camera or by a PC prior to it being used. You may have to do a reset of the camera to get it to behave normally. Keep in mind, that doing this will erase anything saved.
Jun 18, 2013 | JVC GE C1033 10.1MP Digital Camera with 3X...
Memory card is proteted (Reset switch) i reset it and it still says the same thing?
There is a little TINY switch on the side of the memory card, make sure it is not in the "protected" spot!
Jan 07, 2011 | Kodak EasyShare M1033 - black Digital...
When I turn on my camera I get a msg saying " Memory Card is protected (Reset switch on memory card)" Ummm what!!! I can't get this msg to go away, and now I cant take pictures. At the bottom of the screen...
Most SD cards have a little plastic switch, However if you using a SD adapter it might not be fully reading the adapter witch causes this error or the camera is defective.
So if at one point things where hunky Dory and now its saying this try another memory card and if that does not work then the camera is the issue.
Oct 02, 2010 | Kodak Cameras
I have a kodak digital easy share cd33 camera, when I put in a 2GB memory card, it says memory card is full? Do I remove anything 1st from the camera? and what part of the camera if so. thanks
1. With no card in the camera, go into the menu and find "reset"....follow the on-screen instructions. 2. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. 3. Insert card, go into the menu and do the "format" thing again. Be sure to download any pics from the card first.
Feb 27, 2010 | Cameras
Memory Card Problem
There is a lever on the side of the memory card. Pls. switch the position of that.
Your cameras Memory card support : SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
Once the card is readable it is a good idea to format the card.
Good luck.
Nov 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera says Card Locked and I can't Reformat the Memory Card
From the problem described by you, it seem your camera has gone into a internal memory error and hung. Try to take out the battery, the memory card etc , clean and then reinsert and then power on? Try this it might work.... Generally the camera should start working normally once you will take out the battery, since it will reset.
If it still does not work, then think you might need to take it to Canon. They are very helpful and could sort out if you have system software problem. But Before that, I suggest that you must take out its memory stick, the battery etc and keep the camera like that for about 15 minutes. Then only reinsert the battery (fully Charged) and then try to reformat the memory card. If you are lucky, you might not need to go to Canon. Best of Luck.
Apr 30, 2009 | Canon PowerShot A530 Digital Camera
Need Help with Verizon LG VX8100 VCAST Memory
try erasin txt messages too or anything else u dont care bout. try anything that can erase or if u can get a memory card
Jul 17, 2008 | LG Shine KE970 Cellular Phone
Kodak Easyshare C613
Just sorted similar problem on my camera. For some reason, the memory card option had reset itself to Internal only. It needs to be on Auto to take the external card into account. Press on Menu button, scroll down to Memory and select Auto. Hope it works for you too.
May 09, 2008 | Kodak EasyShare C613 Digital Camera
Camera says "memory card full" and there is nothing on the card.
go into the camera's system menu and look for "format card" doing this will enable the camera to utilize the memory card. let me know if this helps, if not there are other things we can try.
Jul 01, 2007 | Canon PowerShot SD1000 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
69 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
