Question about Pioneer Cd Sr100 Steering Wheel Infrared Remote Control
Cd sr 110
Mod
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
Sep 20, 2013 | Makita Drills
How old is my dryer? Kenmore Elite H3 Mod 110 82826101?
you can go to appliance411.com and put in your model and serial numbers and it will tell you how old any appliance is.
Sep 08, 2012 | Kenmore Dryers
I have a whirlpool dry mod#5636 in my home I have 110 the cord on the dryer is for 220 can I change it to 110 and will it work right..
No it will not,dryers with 110 volt plugs heat on gas,220 dryers heat with electric,putting a 110 vac plug on dryer for 220vac,the motor will run but it will not heat
your 2 options are
1) have a electrician come and run 220 vac circuit
2) purchase a gas dryer
Jul 28, 2011 | Whirlpool LER5636P Electric Dryer
Machine was overloaded, did not go through cyle , and now just makes a clicking noise
If its a mod 110 kenmore or whirlpool sounds like broken motor coupler//If its one of those mods i can tell you how to replace...Need Mod # czerney@msn.com
Feb 02, 2011 | Washing Machines
Lost instructions for cooking SR-W06N
most now you can search on GOOGLE.COM for PDF file and down load cheaper than mailing it to you . just type in your MOD # and it comes to you all the info , but be careful of unsafe sites there are Viruses that may attack your Computer ! good luck >
Dec 20, 2010 | Panasonic SR-W06NA 3-Cup Rice Cooker
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Pioneer Cd Sr100 Steering Wheel Infrared Remote Control Logo
27 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
