Question about Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
Lights blink on and off when I plug them why?
Why do my lights blink on and off?
  • Malibu Master
  • 5,245 Answers
The right side is stuckin the up position and all the lights keep blinking.
The physical mechanism is probably stuck. open the toaster and clear it.
Mar 04, 2016 | Breville BTA840XL 4-Slice Toaster
Tip
How to Troubleshoot Blinking Lights on a PS3 Controller
Video Guide to this tip is HERE Accessible>>
The controller for the PlayStation 3 is unique to any other previous PlayStation controller in that it is wireless. The controller is not physically plugged into the system, which means that you can still use it from any point in your room and you don't have to be a specific distance away from the PS3. Occasionally the controller will run into problems, which are often displayed to the user as a series of blinking lights on the controller itself.
Step 1 Move closer to the system. If you get too far away from the PlayStation 3, the controller will not be able to transmit its signal to the system. This will cause the lights to blink and the controller to become unresponsive.
  • Step 2 Recharge the controller. As the PS3 controller is wireless, it operates on an internal battery. If the battery becomes too low, the lights will start to blink, alerting the user that it needs to be plugged into the system to charge. Plug the controller into the system and charge it fully before attempting to use it again.
  • Step 3 Turn the controller on and off. If the lights start to blink and you can't determine the reason, turn the controller off and then back on again. This will clear its internal memory, essentially resetting it. When the controller comes back on it will operate as normal, without blinking lights.
  • Video Guide to this tip is HERE Accessible>>
    GAMES PORTAL ARCADE ON http://playstationportal.blogspot.com/
    on May 29, 2010 | GPS
    Dream Maker Spa lights BLINKING
    possible bad heater element or temp sensor or recirculation pump
    Mar 06, 2013 | Dream Maker Spas Pool & Spa
    Nyko charger won't charge
    Had same problem with blinking lights and not charging.
    Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
    Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
    When plugged in the hose light blinks
    My spotbot lights would blink and it, for a time, only worked on deep clean even after unplugging and plugging back in. Finally it wouldn't work at all, only the hose light would blink. I unplugged the hose and plugged it back in and the machine started working as it should.
    Apr 10, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
    Are the lights on the router stay on or blinking ?
    The power light should stay solid as long as the router is plugged in. The WAN light and LAN lights are solid when you are connected, and the connection is idle. The lights blink when traffic is present. The lights are off when there is no connection.
    Mar 15, 2011 | D-Link DIR601 WirelessN 150 Home Router...
    When i plug it in with out anything plugged into it it automatically starts blinking select green lights is there anything i can do to fix this?
    The all lights will starts blinking everytime the switch is powered ON.
    This is normal process as the switch is checking the status of all its ports during startup.
    Please wait for 5-10 minutes this activity will completed and the port lights will not blink if nothing is connected.
    If it still blinks without anything connected to the ports then you need to ask the vendor for a replacement.
    Jan 08, 2011 | NetGear ProSafe JGS524 (DHJGS524NA)
    My linksys wrt160n wireless router light is blinking
    Welcome to FixYa
    Indication of Router Lights:
    • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
    • Power light turns off for several seconds.
    • All lights, except power light, turn on and then off.
    • Power light blinks slowly, then faster, and WLAN light will turn on.
    • Once Power light and WLAN light are on solid, the router is fully rebooted.
    A working router should show solid green power light. upgrade the firmware of the router.
    If this Helped you-Rate me..Thanks for Using FixYa
    Jun 30, 2010 | Linksys WRT160N Wireless Router
    Simple Tech USB Drive will not work
    I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
    Oct 20, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
    Blinking lights
    I left if off and unplugged for a few hours. When I plugged it in it started working again. My recommendation if this happens to you is to just unplug it all and let it stand for at least 4 hours and then plug it back in.
    Good Luck
    Oct 01, 2008 | Sony RDR-VX555
    Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
    75 people viewed this question
    Top Malibu Hardware & Accessories Experts
    Craig Butler
    Craig Butler
    Gene Haynes
    jdthefixer
    Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
