Question about Frigidaire FFPH44M4LM Silver 4.4 Cu Ft Mini Refrigerator Top Icebox, Energy Star
Reverse refrigerator door opening
Instructions to reverse the door opening
Can't put door on igloo refrigerator model fr3201-b because I don't have instructions and I can't remember. I was reversing the door
ChrisT click on download
click on I am not a robot
then click on get manual
either view in browser or download it
https://www.manualslib.com/manual/282170/Igloo-Fr320.html
the door reversal is in the document
Mar 17, 2018 | Refrigerators
Reverse door
Good morning friend, I appreciate your post!
I see you are trying to reverse the door for your Frigidaire top mount refrigerator, FFHT2117PS. I have successfully located your manual and it provides step by step instructions on how to reverse your doors. Hope this helps. -Matt
Frigidaire Manual Search Results
Jul 23, 2014 | Frigidaire FFHT2117PS 21 Cu. Ft. Top...
SAFELY REMOVING DOORS FOR SHIPPING
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
The doors open in the wrong direction
remove top screw for freezer door remove door then remove next hinge then remove fridge door reverse hinges when putting back on reverse handles to other side
Mar 01, 2014 | Thetford NORCOLD N641R - Norcold Finished...
Whirlpool refrigerator door reversal
Check with supplier first but almost all fridge bodies are made for reversal
Apr 22, 2012 | Whirlpool Refrigerators
Reversing doors on Roper Refrigerator
If the door is reversible you will see plugs on the opposite side and top . pull out the plugs and save . remove handles and hinges and move use plugs on other side
Aug 07, 2009 | Refrigerators
Change the door opening from left to right. Can it be done?
According to the owners manual for the HSB03, there are no instructions for reversing the door, therefore it is not reversible as by the companies instructions. I would not recommend reversing the door, even if it appears as though it could be done. There may be vital components within the unit that are not visible from the outside that could be damaged by the hinge screws in the wrong place.
This is the Haier web site if you need it. http://www.haier.com/index.htm
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Haier HSB03 Compact Refrigerator
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Frigidaire FFPH44M4LM Silver 4.4 Cu Ft Mini Refrigerator Top Icebox, Energy Star Logo
14 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
