Question about Tools & Hardware - Others
Lathe mini operating manual for ML 618mini lathe
Howvdo I change spindles
5 Suggested Answers
SOURCE: operating manual for axminster sieg C2A mini-lathe manual
Hello Tom, I have this manual - quite happy to photocopy it for you if needed? Drop me a line to jimlock1@hotmail.com if you like
Posted on Feb 17, 2012
  • 49967 Answers
SOURCE: How do I change the spindle direction on my fagor control on lathe
I take it that you have tried all the buttons on the panel. As a safety feature it a may require a combination of switches according to the fagor manual item 4 which is he set of 9 buttons bewteen the to turn switches"quote: - keyboard which allows the spindle to be controlled, it is possible to activate it in the desired direction,stop it or vary the programmed turning speed between the percentage values established by means of a spindle machine parameters MINSOVR an MAXORV with incremental steps established by means of the spindle machine parameters SOVRSTEP "
go on line and type in fagorautomation.com/downloads/manuals/en.amn_8055t_opt.pdf for a user manual download.
Posted on Dec 10, 2014
perkins48
  • 14406 Answers
SOURCE: I am looking for a sieg c2a mini lathe manual
Try this link John. http://littlemachineshop.com/info/minilatheusersguide.pdf
Posted on Aug 14, 2015
Testimonial: "Thank you Thomas a very interesting link"
Looking for a live centre and drive end spur for a Mastercraft 554508-0 cast iron wood lathe
Such accessories tend to be universal rather than dedicated to any particular make or model of lathe.
Such accessories are available from many outlets and catalogues containing items for the wood-turning enthusiast.
The tailstock of most lathes would be produced with a Morse taper numbers 1, 2 or 3 and with a variety of adaptors a number of live or dead centres, drill chucks or morse taper drill bits can be used.
Similarly the headshock spindle should be found to have a standard thread capable of accepting a number of chucks, faceplates, drive spurs and so forth.
The headstock spindle thread and the tailstock taper should be listed in the machine specifications and then armed with that information you can shop around a multitude of suppliers to find the best deal.
Apr 19, 2016 | Tools & Hardware - Others
I'm looking for a owners manual for a ML618 wood lathe. I'm looking to see if it has more than one Chuck?
Most wood lathes, like most metalworking lathes, have a spindle that is threaded to accept a variety of fairly standard accessories including chucks and faceplates of various sizes and types to accommodate different types of work.
Any lathe that does not accept a variety of such accessories would be a complete waste of time.
Obtaining a manual for much imported machinery is almost impossible to obtain but most imported machines are close copies of industry standard machines and so generic information such as can be obtained from almost any supplier or experienced user is all that is required.
Oct 19, 2015 | Tools & Hardware - Others
Dec 10, 2014 | Cars & Trucks
Fox mini lathe not running right
Could you be a bit more specific? This is a very simple machine...it either works or it doesn't. Have you checked the belt? Is it binding, or cross-threaded on the drive spindles?
Jun 16, 2012 | Shop Fox W1752 Mini Wood Lathe
Operating manual for axminster sieg C2A mini-lathe manual
Jan 24, 2012 | Garden
Instructions for changing an ammco 3000 brake lathe to a 4000. Parts needed?
Yes, an Ammco 3000 brake lathe can be converted over to a 4000 model--most any year 3000.... preferably the later years after 1970.
The problem with some of the early 60's models is that the cross-feed bore is not perfectly perpendicular to the spindle.
If you convert one of these models, you will cut the rotor at an angle and then jam the machine.
Later models can easily be converted.
You will need...
1) A complete disc feed gearbox.
2) A driven pulley (the big one) set-up for a with a pin drive.
3) A complete spindle lock assembly for the Infimatic gearbox.
4) Possibly need a longer guide bar for the cross-freed. If you have a round guide bar, this is possibly long enough. If you have a "Double-D" guide bar (flat on each side), you most likely will need a longer bar.
5) A complete twin-cutter, with tool guides, tool holders, knobs, etc.
We have all the parts you need for a conversion--or we can convert it expertly for you...
Buy Sell Used Brake Lathes Brake Lathe Parts
Aug 03, 2011 | Ammco Combination Disc/Drum Brake Lathe
Brake lathe chattering bad
There's a lot of reasons why a brake lathe chatters during a cutting operation. They range from lack of maintenance, adjustments, cutting speeds, wrong cutting tools and so on and so forth.
Be a little more specific.
What kind of machine are you using?
What are you cutting? (rotors? drums?)
Are you using the proper silencers?
Come back with some answers please.
Dec 16, 2010 | Ammco Combination Disc/Drum Brake Lathe
Tools & Hardware - Others Logo
13 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
