Question about Nokia N70 Cellular Phone
Split display, LCD problem?
The bottom quarter of screen display becomes a pull out like dialogue flushing very rapidly while showing the same image of the upper quarter. I tried to replace the LCD with a new one and the problem was fixed but after awhile (2-3 hours), the same condition appeared.What can you recommend to fix this problem?
  • 315 Answers
As you said you have already changed the LCD display.... so now you just need to flash(reinstall the software) your mobile.
Posted on Jun 15, 2009
My screen has split in half horizontally mirroring the top with the bottom.
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 17, 2014 | Seiki SC221FS 22 Class LCD HDTV
Philips 47PFL5609D/30 White screen displays on 3/4 of screen
It sounds that the connection between t'Con board to panel have some problems; loose contact etc. Check it. Re-seat them once, and check. If you wish to get more details about faults to Philips PFL series flat panel TVs, check this link.
Feb 05, 2013 | Philips 47 in. LCD HDTV
Compaq C700 laptop screen shows horizontal lines and the screen seems to be split into several sections
The LCD screen is faulty and will need to be replaced, go to www.ebay.com Type: make and model refine search to screen, first! hook a spare monitor to the video output usually on the back, if picture okay! the above mentioned needs to be changed, but! if both show the same symptom it is the video graphics card that is part of the motherboard.
Apr 19, 2012 | Computers & Internet
I came across a Sylvania 6620LE 20 in. HDTV and owner said it had some display problem. Said I could have it if I wanted it. Took it home, plugged it in and it has picture and sound. After about a second...
Yes,this problems it is 90% is the problems and the causes by the T-CON decoders board.10% could be the LCD screen panel itself it is shorted and dead also causes this problems.Tries websites like Shopjimmy.com,Ebay.com also have and sell these refurbish T-CON decoders board too.Tries it u have 90% of sucessfull rate.
Dec 04, 2010 | Sylvania 6620LE 20 in. HD-Ready LCD...
My lg laptop screen seems to be split in 2 almost. It only shows three quarters of the screen and at the bottom the screen starts again
Try to turn off the pc and remove the cables and battery on the laptop. Press and hold the power button for 5 seconds, then reinsert the battery and the cables on the pc. Turn on your laptop and check if the screen will finally splits sucessfully...
May 15, 2010 | Computers & Internet
The display cuts off the bottom quarter of the image
you have a weird display resolution set somewhere on the laptop. The vplcs7 is relatively old. It only supports 800 x 600 (SVGA). If you are cloning your monitor, you need to set the output to the projector also to 800x600. Depending on how your laptop is configured you may need to set your laptop monitor to 800x600 while using the projector, then going back to the normal resolution when you are finished.
Feb 02, 2018 | Sony VPL-CS7 Multimedia Projector
Pentax a10
Ok here it is open the camera and re insert the fine lcd ribbon into is holder problem solved. Your camera must have had a sharp knock to dislodge the lcd screen and pulling out the ribbon. Worked for me.
Cheers
Feb 19, 2008 | Pentax Optio A10 Digital Camera
Problem is with nokia 6600
1st try to change the smal 6link ic under the display filter,f same result change display filer
Sep 02, 2007 | Nokia N70 Cellular Phone
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Nokia N70 Cellular Phone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
