Question about Hoover PE235 Front Load Washer
Need manual for klasse washer dryer combo - Hoover PE235 Front Load Washer
LG WASHER/DRYER COMBO PF Issues
pf is power failure,, need to replace main board... there should be a parts/repair manual inside unit.. usually bottom panel...
Aug 15, 2016 | LG Washing Machines
I have an ariston washer dryer combo. today I turned it on to do a wash cycle. the knob no longer clicks or shows the times of other cycles. I've turned it off and on a few times but nothing helps
Ariston armf 125 washer dryer combo - YouTube
? 4:14
www.youtube.com/watch?v=zPtG5Q3qQ3Q
Oct 23, 2010 - Uploaded by troykm Rinse cycle. Correction - it does do 3 rinse cycles!! :-)
[PDF]Instruction Manual - Ariston Appliances
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf
WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Sep 22, 2015 | Washing Machines
My frigidaire washer dryer combo does not agitate but when i turn on the dryer the washer turns on too. what can i do?
You have a problem with the lid lock assembly and it will need to be replaced. Here is the part to order. I also have the service manual if you should need it.
Nov 23, 2012 | Frigidaire FEX831CS Top Load Stacked...
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
Need operating instructions for supra washer/dryer combo
I can forward you the PDF manual for this unit. There doesn't seem to be a way to post the file here.
May 14, 2009 | Supra SW5L50D Front Load Washer / Dryer
Need operating manual for Bendix WDC1025 Washer dryer combonation
This is the same machine or nearly identical machine as the Splendide Comb-o-matic 6100, for which you can find the manual here:
http://splendide.com/request_manual.htm
Mar 31, 2009 | Dryers
LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Jul 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Hoover PE235 Front Load Washer Logo
18 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
