Question about Lionel New York Central Flyer
L electrical wire connections
Idon't know how to connect wires
I have the battery compartment wires connected correctly ( as per YouTube video) and the red lights work
Electrical: Circuits, Relays - SwedishBricks
www.swedishbricks.net/700900FAQ/Electrical-CircuitsRelays1.html
Electrical: Circuits, Wiring, Relays, Switches FAQ Home ... 3. Corroded harness connections cause most intermittent circuit failures. ... When they do fail, the failure will be predictable, such as a bad current or ground connection, blown fuse .... Here's a generic statement about your relay (which I know nothing about) -- this ...
GM Passlock Security Fix - Bergerweb.net
www.bergerweb.net/PasslockFix/
Mar 8, 2012 - This normally works! ... In GM cars, there is a bundle of three wireswhich go from the Body ... through a hole in the radio compartment toward the steering wheel. ... Find the three wires that connect the Passlock Sensor to the Body ... withblack fabric tape, unwrap them and separate the three wires so you ...
Jan 19, 2016 | Electrical Supplies
Have a Carrier Electric Furnace & AC, Model #FA4CNF048 and need to know how to connect a Blue wire to power to supply C wire for new Honeywell Wi-Fi thermostat. Any Suggestions?
C is common for 24 volts from the a/c transformer secondary or low side. R and C are 24 volts and will power up loads of 24 volts such as thermostats requiring to be powered up,
C is usually grounded or connected to the metal of the a-c unit. Use any color available to connect the wi-fi thermostat C to the a-c C to deliver 24 volts to the thermostat.
Jul 06, 2015 | Carrier Heating & Cooling
There are 7 wires from the control unit.All wires are connected except the blue wire with yellow stripe and the bike is not sparking.Can you help please as there is no sign of where the wire should connect...
I don't know the actual colours of the wiring loom, however the diagram linked below shows all the electrical components. Whatever connection the blue/yellow wire has, look for the corresponding male or female connection.
Cheers.
http://www.boats.net/parts/search/Yamaha/Motorcycle/1988/DT50L/ELECTRICAL%201/parts.html
Jun 25, 2011 | Yamaha Agusta F4 SPR Motorcycles
1998 chevy 1500 pick up. good fuel pump, new fuel filter,fuel relay good. starts good, dies instantly. what to check next.
If your fuel system is all correct and working it needs to be an ignition problem-and the usual suspect is the crank sensor, which coincidently does not set a CEL-so, since it is very inexpensive (usually less than $50) and not difficult to change int a 350, take a chance there-you could try to remove the connector and clean off the connection first-worth a shot.
May 26, 2011 | Chevrolet 1500 Cars & Trucks
How do I know if I have a 3-wire or 4-wire system connection for my samsung electric dryer?
Remove the back panel where the wire is connected to the dryer...
Here is the hookup for 3 to 4 or 4 to 3 wire hookups
Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Dec 12, 2010 | Samsung DV218AEW Electric Dryer
I want to fit a light and switch into my new workshop. I have a garage type consummer unit fitted and am not sure how to wire in the light.
I answer questions for free.
I know electric wiring.
However I might not understand your problem.
If I do not understand your problem, add a comment with more information and I will respond.
If I understand correctly you want to add a new switch and a new light in your garage.
And you are starting from scratch with no knowledge.
You are starting with a blank wall.
I do not know what a consummer unit is.
Is that a type of light?
Here's a sketch of the project:
We need an electrical receptacle or wall-plug so we can get electricity.
We need to run a cable from the electrical wall-plug to the switch.
This will bring electricity to your switch.
And then we need to run a cable to the light.
Let's talk about how you get electricity from the wall-plug.
The wall plug has a black and white wire connected to each side.
Your cable has a black and white wire.
You connect your black wire with the black side.
Connect white to the white side.
Now run the cable to your switch.
The cable arrives at the switch.
The cable has a black and white wire.
The switch is wired differently than the wall-plug.
On the switch you connect one black wire.
But the white is not connected to switch.
Now we're ready for the cable going to the light.
The cable to the light has a black and white wire.
Connect the black to the switch.
So now you have 2 black wires connected to the switch.
The black wires are on different screws.
And then connect the two white wires together.
So the switch is wired.
Run the cable to your light.
The cable arrives at the light.
The cable still has a black and a white wire.
Your light will have wires -or- it will have screws.
If light has black and white wires, then connect black to black and white to white.
If your switch has screws, then connect black to brass-screw and white to silver-screw.
Oct 30, 2010 | Electrical Supplies
Wire connections for electric dryer. How to
The following link explains how to connect a 220VAC appliance cord to an electric dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
There is a difference in how the 3-wire and 4-wire configurations are terminated. Read through the instructions throughly and let me know if you have any questions. I hope this helps you.
NOTE: Homes built after 2000 are required to have a 4-wire configured outlet to be in compliance with the National Electric Code. If you live in an older home that currently has a 3-wire configuration you are not required to upgrade it.
Feb 18, 2010 | Maytag Neptune MDE5500AY Electric Dryer
ASEA CYLINDA 1200 Dish Washer Electric Motor Wiring Connections
A neighbour happened to call in and popped the right wire in the right place and presto we were in business. Not sure what he did but it worked. thankyou. wal
Nov 15, 2008 | Dishwashers
Electric Baseboard thermostat wiring
what is the make of the thermostat? are the heaters 240 volts?
Jan 27, 2008 | Heating & Cooling
Lionel New York Central Flyer Logo
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
