Question about 2006 - 2010 Jeep Commander Grille 060-99-1 Jeep
My Airbag light is on,
I have the Airbag Codes: B1B2AB and B1B2EB, I just bought my 2006 Jeep Commander and the light was on, they said it was probably a sensor but a friend ran the scanner and came up with these codes... Please help...
Bas/esp light is on inmy jeep commander 2006
This video is for a liberty, but all Jeeps should be similiar.
Jeep Liberty How to fix Traction ABS EST Light Codes C1240 C123F Also a guy in a forum says that it might involve a recall of the DCX recall applying to ABS modules on many Chrysler, Dodge, & Jeep products including the Commander. I'd call your dealer and ask, they might fix it for free if it's a recall. http://www.jeepcommander.com/forums/5-general-commander-discussion/1483-esp-bas-traction-control-light-staying.html
Nov 17, 2016 | Jeep Cars & Trucks
Jeep 2006 Malfunction Indicator Light & ESP/TCS Indicator Light
go have the vehicle scanned for trouble codes most auto stores offer this service for free the codes will help in assisting repair
Jul 31, 2017 | Jeep Cars & Trucks
Bought a used jeep 2006 commander all yhe lights have been going on and air bag lights No one can tell me why. Any help would be appreciated
  • mine did the same thing and I had it in the shop several times. Chrysler had a guy to come to the shop where mine was and found out that the electric had shorted out from the a/c. So they had to take out the whole dash and re-wired. $650.00, now if you have not gone over 75,000 it will still be covered. hope this helps. Aliso
Nov 23, 2013 | 2006 Jeep Commander
2006 Jeep Commander
check transmission fluid level could be low if vechicle has 60000 time for fluid filter change.if all is good have transmission shop do diagnostic check using scanner check transmission see whats causing light to flash on.
Jun 19, 2013 | Cars & Trucks
Warning lights go on and off....2006 jeep commander
that code means the computers are not communicating
Aug 21, 2012 | 2006 Jeep Commander
2006 Jeep Commander V8 Iimited 4.7 will my eng light come on at specific mileage milestones? 70k
No. The only time the check engine light will come on is when the computer sees a fault with a sensor, a problem with a component it controls, or a problem with a system that it monitors. Your best bet is to have the computer scanned to see what codes are present. Once you know that post them here and i'll be happy to help you further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Aug 24, 2011 | 2006 Jeep Commander
2006 Jeep Commander inefficient catalyst
most likely the oxygen sensors (lambada) ,they need changing ,their are two one before the cat and one after,do not think you need a new cat unless it has a min of 150.000 miles on the clock
Jul 02, 2010 | 2006 Jeep Commander
2006 jeep commander check engine light stays on after jeep sat for 5 days in ice storm and was not started
I don't think I would be concerned about the vehicle sitting for 5 days. Get it scanned and work on a fix,for why the light came on.
Feb 15, 2010 | 2006 Jeep Commander
2006 - 2010 Jeep Commander Grille 060-99-1 Jeep Logo
Top APN Auto Body Parts Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an APN Auto Body Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
