Question about Injen Short Ram Intake 1991-1995 Acura Legend V6 3.2L POLISHED IS1401P
Need intake manifold torque specs
How many lbs to tying up bolts
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
02 WIMDSTAR TORQUE SPECS INTAKE MANIFOLD AND SEQUENCE
always start in the middle, then work your way to the ends on alternating side bolts, bolts are probably 10mm or 3/8", if so around 18-24 ft/lbs torque maximum. don't use sealant on the intake manifold and the rocker cover should be 6mm or 1/4 bolts, same sequence just less torque, 10-12 in"/lb max
Jul 24, 2014 | 2002 Ford Windstar 3.8L Intake Manifold &...
1994 mpv 3.0 torque specs intake
Torque Specs :
Intake manifold bolts...72-105 in/lbs or 6-9 ft/lbs
EGR valve bolts........165-225 in/lbs or 14-19 ft/lbs
Remaining little bolts for brackets, etc......72-95 in/lbs or 6-8 ft/lbs
Aug 04, 2012 | 1994 Mazda MPV
Looking for cylinder head torque specs and intake manifold torque specs
on the 2.5 4 cylinder
step 1 18 ft lbs.
step 2 26 ft lbs. except bolt #9 re tighten it to 18 ft. lbs.
step 3 all bolts an additional 90 degrees.
intake manifold bolts 65 ft lbs.
on the 3.3L V6
step 1 35 ft lbs.
step 2 tighten all bolts an additional 130 degrees
step 3 tighten center 4 bolts an additional 30 degrees
intake manifold bolts 88 in. lbs.
Jan 13, 2011 | 1992 Buick Century
Need torque specs for 2000 chevy malibu 3.1 cyl heads & intake
(step 1 ) the torque specs for the heads are---1998 through 2001 are 37 foot lbs. ( step 2) rotate an additional 90-degrees (1/4 turn). intake manifold bolts ( lower ) step 1-- 62 in-lbs, step 2--115 in-lbs. intake manifold bolts/studs ( upper ) 18 ft-lbs. this is for the 3.1 v-6, have a good day!
Aug 14, 2010 | 2000 Chevrolet Malibu
Need torque specs for a 2001 jeep cherokee intake manifold
Intake manifold using new gaskets. Torque the bolts, in sequence, to 105 inch lbs. (12 Nm)...
Fig. Intake manifold torque sequence-3.7 & 4.7L engines
Hope this help (remember comment and rated this).
May 07, 2010 | 2001 Jeep Cherokee
Need head bolt, intake manifold, and exhaust torque specs
Cylinder Head Bolt Step1- (25 FT.Lbs) Step2(45 Ft.Lbs) Step3(65Ft,Lbs).....Intake Manifold(35Ft Lbs)....Exhaust Manifold Center (20Ft Lbs) All Others (20 Ftlbs).....Thanks
Mar 06, 2010 | GMC Suburban Cars & Trucks
Intake manifold bolts torque and rocker arm torque
Intake Manifold Coolant Pipe Bolt .... 89 in lbs (7.4166 ft. lbs)
Lower Intake Manifold Bolt .............. 115 in. lbs (9.5833 ft. lbs)
Upper Intake Manifold Bolt/Stud ...... 18 ft. lbs
Valve Rocker Arm Bolt ................... 168 in. lbs (14 ft. lbs +30 degress
Feb 06, 2010 | 1999 Buick Century
Need to the torque specs for a 1999 Dodge Durango
Head Torque sequence Step 1: torque to 50 Ft/Lbs Step 2: torque to 105 Ft/Lbs recheck final torque in sequence.
Torque intake manifold: Step 1: 12 inch/Lbs, (hand tight) Step 2: 72 inch/Lbs, (6) Ft/Lbs Step 3: 12 Ft/Lbs
torque intake plenum: Step 1: 24 inch/lb (hand tight) Step 2: 48 inch/lb (4) Ft/Lbs Step 3: 84 inch/lb (7) Ft/Lbs (To torque bolts, start in center using crisscross pattern)
Apr 07, 2009 | 1999 Dodge Durango
Injen Short Ram Intake 1991-1995 Acura Legend V6 3.2L POLISHED IS1401P Logo
82 people viewed this question
Top Injen Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you an Injen Wine and Spirit Expert? Answer questions, earn points and help others
