Question about ASUS Eee PC 900 Notebook
The " and @ keys are reversed. I am using the shift key.
FYI other keys are working.
Funtional keys are not working in lenovo
Function keys on many laptops are used as the secondary set and the individual functions of the keys have been shifted to the primary functions. Thus, if you press F1 and things are normal, you would get some kind of "help" But if, as in many laptops, the functions of those "F" keys has been reversed you might get an Internet key, a brightness key, some kind of CD opening key, or whatever the manufacture decided. F2, as another instance, is used to trigger "edit" of the current item....but in many laptops pressing F2 just turns off your wireless signal or dims the screen slightly. In those cases the way to access the expected Fkey functions is to hole the Fn key down (at the bottom left of the keyboard) then press the desired F key. Personally I find it nuts to have reversed an PC age old way but I'm not in charge of keeping people happy so it's not happening.
Hope that helps.
Dec 18, 2014 | Lenovo IdeaPad Z560 Laptop
Why would my '02 Olds Alero suddenly not shift into reverse?
My guess is the ignition needs to be replaced. check to see if theres a recall for it. 2 years ago on my 2002 alero I found a recall for the flasher switch which was causing intermediate directionals and 2 more for the computer
Jun 30, 2014 | 2002 Oldsmobile Alero
1991 deville starts and dies then won't try to start again until the key is off and tried again
Hello there,. I got some dough to put down on this one.
First, I'm assuming, maybe a long stretch here -- Do you have a lot of weight (numerous keys or other) on the key chain which you use in your ignition??
If this is the case, you most likely have a worn ignition switch that crapped out.
If not, then you have a real good question where I'd like to see some more details -- how was the car running before on start up, # miles? what about the transmission shift linkage - is it worn? is it on the steering column? have you tested the shifting lever switch inside to see if it crapped out? Did you try to work the gears back and forth to test the switch?
FYI:... sorry for the slow response time, been BURIED with life in general - thought someone else would have picked up your question by now!
Best regards
Ck
Oct 19, 2011 | 1991 Cadillac DeVille
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
My shift key wont work at all
Holding down both shift keys at the same time wont work. Chances are you have a dead key. use the other shift key instead. if a program is mapped to use specifically that shift key, remap it to the opposite one.
If you are using a desktop, replace the keyboard; if it is a laptop replace it if you can yourself, otherwise, call a computer technician.
Jan 03, 2010 | HP Computers & Internet
Cant shift into park and key stuck in ignition
USE A WRENCH AND STREACH THE KEY HOLE WORKED FOR ME!!!
Mar 26, 2009 | 1994 Mazda MPV
Gear shift lever wont go into park; there's no problem with transmission or fluid vehicle works fine but i cannot get the shift lever to go into park, also i can remove the key while its in the reverse...
I have a Dodge Charger 06 model and the gear wont move from Park to reverse. everything else works as far as gas, brake light, etc but my gear wont shift can i get soem help
Nov 05, 2008 | 1996 GMC Jimmy
Acer Laptop
sounds like a keyboard airing out, or a replacement session.
Feb 26, 2008 | Acer Aspire 5500 5570-2609 Laptop
ASUS Eee PC 900 Notebook Logo
18 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
