Question about Husqvarna Garden
Ignition break down under load - Husqvarna Garden
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Husqvarna Expert
  • 188 Answers
This can happen when the saw gets hot. If the coil is breaking down under heat /load it must be replaced. There is no repair.
Posted on Feb 03, 2016
Why my vx commodore breaking down under load
Hi if your car is missfiring breaking down under load is usually in the spark circle ckeck sparkplugs for correct gap or if just old , replace to test if coil or ht leads drive vehicle in top gear 4 th or 5th doing 1500 rpm put your foot hard to thefloor to load up the motor if leads or coils are faulty they will break down now at the lowest reves u can do with throttle wide open check ht leads with a molty meter, if suss replace same as coils , also make sure if your coils bolted to a plate it has a special heat grease on it between coil and plate , repco ect has it .if car is auto it is harder to load it up u may be able to disconnect kick down cable , get to top gear just crusing hit throttle to load up , or just from standing start but try not to break traction .make sure have correct fuel ,run motor at night no light at all some times u cansee sparks from faulty leads and coils all thebest if in dough replace one part at a time
Aug 27, 2014 | Vehicle Parts & Accessories
CAR STARTS WHEN COLD BUT NOT WARM
Electrical resistance increases with temperature, If the problem lies with your ignition system then something is likely to be breaking down under load. I would suggest having the exhaust emissions checked when engine is hot to rule out a fuelling problem.
Dec 10, 2012 | Ignition System for Subaru Justy
Just put a 70cc bore kit on My Gilera new 21mm carb n new spark plug but spuds like it miss fires at high revs
Possible defective or leaking spark plug boot or wire or defective ignition breaking down under a load like a possible coil.
Jul 15, 2012 | Motorcycles
99 ford e350 runs rough in overdrive
most likely the ignition system is breaking down under load and it's heaviest load would be in overdrive common ford problem start with plugs and wires see if this helps.
Jul 31, 2010 | 1999 Ford Econoline
Why does a spark plug fire at idle but not on acceleration ?
You may need to check the ignition wires and the distributor cap/rotor.
Older ignition wires will "break down" and the spark will actually short out on nearby metal/engine block etc.
Try this test. With the car running, parking brake set, and foot firmly holding the brakes, put the car in Drive and accelerate. If the engine misses under a load, it's most likely the ignition wires..
Jul 09, 2010 | 1991 Ford F150
Ryobi strimer runs for 15 minuets cut out cooles down restart half hour
your problem is most likley a fuel tank breather problem or a ignition coil is breaking down under load and heat
retest unit again with tank cap loose if it does it again ignition coil is breaking down
cheers pauly46
May 19, 2010 | Garden
I have a problem with car cutting out at 2500 Rpms, changed fuel pump didn't help have any suggestions.
check coil, coil wire, spark plugs... sounds lie ignition break down under load... please rate my help...
Aug 05, 2009 | Dodge Intrepid Cars & Trucks
Vl break down under load
Yes, you have symptoms of ignition break down. primarily plug wires. Double check plug gap & wire gauge (7mm 8mm). Ok, Bosch air meter has two adjustments, using a very long allen wrench (thinking 5mm) insert throu removed plug forward of air boot top of housing. with engine running turn 1/4 counter clockwise, may try several adjust until performance has improved. This IS NOT a fix only a personal diaagnosis temp. this should improve engine performance. The proper fix is lenthy. If improvement is noted then let us know and we will help the permanet fix. Rick
Feb 22, 2009 | 1999 Volkswagen Passat
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
