Question about Honeywell he300a1005 furnace humidifier,fan powered
He300a leaks leaks water
My Comfort-Aire Dehumidifier has started leaking water. The unit works fine but the water bucket does not retain all the water. As the bucket fills there are slow leaks. Also, sometimes when replacing the...
It can have leaks from the condenser to the bucket. The piping and hoses should be checked all the way. Perhaps even replaced or at least cleaned. I don't think it is wise to do this yourself. Because in the system also can be algae, bacteria and viruses. And you need tools and skills to replace defective tubes, pipes or gaskets.
Oct 10, 2014 | Dehumidifiers
Dehumidifier seems to be running fine, but water leaking on floor even with minimal water accumulated in bucket?
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
Sep 13, 2014 | Frigidaire FDF50S Dehumidifier
Why is my Frigidaire dehumidifier leaking water from the bottom of the unit?
Hi friend, thank you for your post!
I have identified that a few possibilities to why water is leaking from the bottom of your dehumidifier could be a crack inside your bucket or condensation from the bucket. I would remove your bucket and look it over to see if you can locate any visible cracks or chips. How much water is leaking from your dehumidifier? If you can provide any further information I look forward to assisting you. -Matt
Sep 03, 2014 | Dehumidifiers
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Oct 23, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Our Whirlpool gold dehumidifier is leaking water. We have checked the water reservoir and it is in correctly and continues to collect water. But, water is seaping onto our floor from the dehumidifier.
Do you use a hose with your dehumidifier? Could it be leaking? I have two machines in my basement. I use hoses on both. I had to do funny stuff to make the hoses not leak on the plastic 'blown' tanks. Even the cap that originally came with the machines were leaking before I started to use the hoses.
Check for holes in the tank as well.
Sep 27, 2009 | Dehumidifiers
Dehumidifier leaks
Either there is a hole/leak in the tray, or the drain line is clogged. You are giong to have to access the tray to determine this: standing water is plugged line and no water is busted pan. This will determine your avenue of approach.....
Aug 31, 2009 | Ebac Neptune Dehumidifier
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
Dehumidifier m7dh65b2a
Mine leaks. Had leaked at other times but i took the vacuum cleaner to the front drain spout, that leaks into the removable basin. That worked in the past, but i't's not working now . The water is overflowing at the back of the catch tray and leaking out through the bottom underneath. The holes are clear, so it shouldn't be doing this. I am stumped.
Jul 04, 2008 | Maytag M7DH45B2A Dehumidifier
Honeywell he300a1005 furnace humidifier,fan powered Logo
42 people viewed this question
Top Honeywell Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Honeywell Dehumidifier Expert? Answer questions, earn points and help others
