Question about Music
I am in a ukulele ensemble of 8. We all have electric pick ups in our ukes. what is the best way to connect to one amplifier, eg; using a mixer ?
Best way to connect to a PA system
    Sergeant:
  • 336 Answers
It can plug into a guitar amp or PA system both. If you use an amp, you could hear yourself alone through that, then output jack "power amp out" to PA or put a mic in front of it from the PA. If you don't use an amp, it can plug into the PA but, you would only hear the 8 pieces together and have no way to hear yourself seperately.
Posted on Mar 29, 2014
  • 101 Answers
SOURCE: PV 1500 Amplifier
The final out put amp stage is out. MOSFET transistors likely. Hope this is helpful.
Posted on Nov 03, 2009
  • 5603 Answers
SOURCE: I have purchased a beheringer 1832fx usb mixer and
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Posted on Sep 06, 2010
  • 1138 Answers
SOURCE: hiwhat is the best way to connect my DigiTech RP10
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Posted on Oct 23, 2010
  • 5603 Answers
SOURCE: Actually I have a Mackie ProFX12 Mixer but it is
If you plugged into stereo channel 9/10 that is an input channel... That will not work...
you need to connect to a stereo OUTPUT.
If you have a "tape out" set of connectors try that... or a main L and R output.
Posted on Nov 26, 2010
  • 298 Answers
SOURCE: Can I connect this mixer
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Posted on Feb 10, 2011
How to connect it ?
Instructions
    • 1
      Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
    • 2
      Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
    • 3
      Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
    • 4
      Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
    • 5
      Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
    • Audi Performance Chip
Jun 19, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
I have a beringer sx3242fx, i need to know the best compatible amplifier to use my samson speaker that pushes up to 500 w
Almost any amplifier will work so there is no "best"... Just make sure the amp RMS rating is a bit below the RMS rating of the speaker for safety of the speaker. A QSC GX5 would be a candidate. You would use one side of it for each speaker if you have two, or use only one side for a single speaker. A lot of pro's seem to use these amps. USE BALANCED interconnections either XLR or TRS cables AND for sure power the amp and the mixer from the same receptacle... it often means running an extension cord like the pro's do to avoid ground bounce noise AND damage to the equipment.
Sep 02, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
Would I need a mixer or amplifier with this product: Pyle-Pro Rack Mount 8 Channel Wireless Microphone System with 8 Lavalier/Headsets (PDWM8900)
The unit has a built in mixer as well as individual outputs. You would need an amplifier/speaker that could receive from teh mixed output jack of this. Use BALANCED TRS cable.
Aug 20, 2011 | Pyle PRO 19 RACK MOUNT PRO DJ MIXER SFX
Marshal mg15fx : Noise when i connect the amp to a mixer.
Mixer uses balanced outputs, this unit does not... Also ground loops can be a problem. Make sure this and the mixer are BOTH powered from the same receptacle. The next problem is that the level of the mixer is MUCH too high for an amp designed to recieve guitar signals if you are sending a mixer into this. It is NOT clear how you are connecting this to a mixer... IF you happen to be trying to send signals from this to a mixer, either use a mic OR use a Direct Input box. You should tell us exactly how you are connecting this to the mixer since there are MANY ways, and most do not make sense.
Aug 07, 2011 | Marshall Amplification Marshall MG15FX...
How to hook up speakers? Sound sounds muffled
You DON'T connect speakers to this... this is NOT a powered mixer... you MUST use external amplifier !!!! You use bvalanced (TRS) cables to a suitable power amplifier which connects to speakers. Some Behringer mixers such as the PMP5000 have built in amplifiers to drive speakers... yours does not.
Jul 23, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I just went to change the 9v battery in my eleuke ukulele and i was a bit distracted and accidentally put it in the wrong way. now the electronics do not work. does the ukulele have a fuse which i blown or...
There is no fuse... SOMETIMES the battery contacts get bent when battery is put in backwards due to the shape and size of the two connections. Verify the contacts in the uke are OK. Beyond that have a COMPETENT electronics person check it out. Often these have a protecting diode that prevents damage electronically.
May 25, 2011 | Electric Eyeware Eleuke Blue MP3 K-Series...
Hi what stuff can i wirer up to it and how can i wirer it up and can i use a ordinary amplifier for speakers. Christopher
what do u mean wire up u have 8 channels so u could have 8 mics 8 inputs etc and yeah if can use an amp unless its got one already in it
May 08, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I'm not sure how to put the string swing ukulele hanger inthe wall!!
It should come with mounting hardware, including screws and anchors. You'll need to:
1. Locate a stud in the wall.
2. Position the hanger where you want it.
3. Mark where the screw holes are.
4. Using a 1/8 in. drill bit, drill pilot holes on the marks you just made.
5. Put the hanger back up to the holes, and insert the screws.
If you have to use wall anchors, these should go in after drilling the pilot holes, but before screwing down the hanger.
If you need any clarification, let me know!
Hope that helps!
Feb 09, 2011 | String Swing Ukulele Wall Hanger w/ Wall...
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
What is the best suited power amp for the Peavey PV14 mixer board?
that depends on your speakers, not the mixer. the amp should be matched to the speakers, in watts and in ohmage. for example, 400 watt, 8 ohm speakers should get an amp that runs at 350-500 watts at 8 ohms.
Apr 22, 2010 | Peavey Pv 2600 Power Amplifier
Music Logo
175 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
