Kdf e5520TV turns on, stays on for like 10 secs then turns off power light flashes 4 times over and over. what could it be? i just replaced the lamp did i do something wrong?
Turns on, stays on for like 10 secs then turns off power light flashes 4 times over and over. what could it be? i just replaced the lamp did i do something wrong?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Its go to safe mode
some thing wrong some signal are missing its go to safemode
Posted on Apr 29, 2014
  • 4234 Answers
SOURCE: Power light flashes 4 times
The 4 blink code usually indicates a loss of vertical deflection. Check the solder connections on the vertical IC. If the connections are OK, replace the chip as it is defective. This chip will be a small flat IC with about 1 pins or so attached to a heatsink. It will be marked LA3847 or something similar.
Keep us posted.
Dan
Posted on Jun 12, 2008
welcomejee
  • 10594 Answers
SOURCE: SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
Posted on May 18, 2009
SOURCE: TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Posted on Jun 29, 2009
  • 83 Answers
SOURCE: sony wega #KDF-55-WF-655 won't turn on: goes to standby mode
don't wory sir , may i help you .
this is a not mager problum but sum times technicean is parsnal baneefits besness and fast money making this rongh dignosis and canfused to castamer so don't wory ...
[1] problum is in side tv set in out put voltage form EHT becose your tv is red and green light is ok then SMPS is ok
pls. check with tv techicean and follow sum tips
* voltage check From EHT out put and canacting spear.
* H- out put tangester and cancting sperar
* H out put tarngester base tarminal voltage check if ok then 100% problum is EHT or canacting spaer so don't wory all spear is not very expancive pls.find Best tech.and solve this problum Esely
best of luck...
Posted on Jan 31, 2010
hardrocko
  • 1476 Answers
SOURCE: wega KDF-E50A10, no picture, standby lamp flashes
You have a problem in the vertical drive section. Probably need to replace the vertical IC and maybe associated resistors. Let me know how you make out.
hardrocko
Testimonial: "Thanks for the info. Seems crazy to have to replace something like this for a 2 yr old TV. Any idea what cost I'm looking at?"
Red light flashes 3 times
hold in on the power button for 10 sec make sure you put the cover on it good first if that dont work unplug it for a few sec then try to hold the power button down for 5- 10 sec that should work
Jan 06, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a sony wega kdf-42a10 its only years old. i already replaced the bulb about a year ago....now when i turn it on the picture comes up then is there for about 4 to 5 sec. then disapears... they...
The tv also have a board that called a Ballast board this board only job are to ignite the tv lamp only.Hear alot of clinking too while the stanby light are blinking.Yes,the Ballast board it is dead and not help to ignite the lamp and helping it stay on.
Aug 25, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tonight my Sony Wega KDF-42WE655 screen went black and the audio stopped, the standby light (green) blinked on and off for about 30 sec. then the screen came back on and the green light blinked 5 sec or so...
Replace its lamp as existing lamp has been reached at end of its working hours life and need to replace to solve this issue. Please note lamp is not not broken or dead yet so you do not see lamp light on tv front.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for god picture in tv.
Thanks.
Dec 31, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
While I am watching TV on my Sony kdf-60xs955, the screen goes blank and the green light just flashes. Sometimes it comes back on and sometimes not. I hit the power button and the red light flashes 5...
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Check by changing the Power cable to any other wall outlet in your home
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
Sep 22, 2009 | Sony (XL-2400) Projector Lamp for...
No picture
CHECK THE LAMP DOOR THIS IS A LAMP DOOR ERROR.
Jun 13, 2009 | Sony KDF-50E2000 50" HDTV
KDF-55WF655 Power Issues
Solution # 1 was no help - I talked to some moron at Sony who said to contact a service person. Waste of 30 minutes.
Here is what I did:
I was having the same problem. I am no expert, but what I read on-line is that it was likely the lamp needing replaced, that the lamp toward the end of its life will flicker and cause the TV to "reboot". I had no Red Lamp replacement light, so I wondered if that was really the problem. But, I bought a replacement lamp for $110 plus shipping, and replaced it last night - TV is working great now. I would try replacing the lamp on yours first yourself (if the lamp is older than 2 yrs), then if that does not work, contact a service person. Don't have a service person replace it, because I have heard many people say they paid $400 for a replacement lamp service, and I did it for under $140 with overnight shipping charge for the new lamp. My original lamp lasted 4 years, so I was lucky to not have this problem sooner. As long as the green light is flashing more than 10 times before the picture comes back on, it is likely the lamp. For 10 or less flashes it could indicate another problem.
Hope this help!
Jun 17, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
My sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
Jan 18, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
