Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
TV COMES ON THEN SWITCHES OFF. - Samsung LE32R74BDX 32 in. HD-Ready LCD Television
  • 6,784 Answers
Hi. this is the result of a weak and failing inverter board. this board will need to be replaced asap.
Posted on Jun 21, 2009
Tv switches to off/standy
Check and replace its front/side panel switch board. Contact any service technician. Gopakumar Gopalan Google
Feb 27, 2014 | Toshiba 32BV502B 32 in. LCD HDTV
I have a philips 42pf55000.switches off ,renove mains ,comes on again ,but no burning smell
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
When I switch tv on at button on tv I van hear the tv goes on. No Picture. If I press buttonds on the remote I can see the red light come on that indicate the remote is sending signal. Here comes the best...
Replace , front panel switches , one or more switches goes high resistance
when suppose to be open circuit , my sv2918 74cm was doing weird things
with these switches going bad
May 10, 2011 | Sansui D 27" TV275 TV
Whatever I listen to, the sound comes out of my tv instead of my speakers, although when i checked the speaker volume there working
Free PDF Instruction Manual at the link below.
http://download.p4c.philips.com/files/h/hts3154_05/hts3154_05_dfu_eng.pdf
Check Page 10 Point 2.
b Source buttons
- DISC/USB: toggles between DISC or
USB mode.
RADIO: toggles between FM and AM/
MW band.
TV: switches to TV mode. The sound
from the TV will output through the
connected speaker system.
AUX/DI: switches to the external device
that is connected to the AUDIO IN-AUX
socket.
MP3 LINE-IN: switches to audio device
that is connected to the MP3 LINE-IN
socket.
Apr 17, 2011 | Philips HTS 3154 Theater System
Have a Mitsubishi TV wd60735 the tv volume just increases to max by itself, sometimes won't turn on, sometimes no remotes will work it and I have to pull the plug to reset it to get it to come on, have it...
Sounds like your tact switches on the front of the TV are shorting out. Unplug the plug for the switches. if the problem goes away then try to clean the switches with rubbing alcohol, if still has problem replace switches.
Aug 27, 2010 | Mitsubishi WD-60735 Projection Television
Tv comes on and then turns off automatically.
This sounds like the front panel assembly(FPA) switches are acting up. What happens with this model is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Let me know if you need more help or info.
Nov 05, 2009 | Televison & Video
40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Jul 15, 2009 | Westinghouse Electric VK-40H580D 40 in....
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
