Question about EverFocus EHD730 Ultra 720 TVL Outdoor True Day/Night Camera with
When ir go on the everfocus ehd 730 picture ghosts
Picture washes out when infra red go on
What is the code for a yamaha dsp -ax 620receiver codes
PS3 BD remote is Bluetooth, not infra red. Bluetooth and Infra red are two different ways of transmitting signals. They are not cross-compatible. So there's no code to allow a PS3 BD remote to operate any Infra red device becuase the PS3 BD remote does not issue IR commands.
Aug 17, 2014 | Audio Players & Recorders
How do you convert it to infra red
Take your camera apart and find the ccd.
it will be under the yellow wiring ribbon like in this picture http://www.ifixit.com/Guide/Disassembling+Canon+Powershot+SD880+Flash/4647/1
remove the ir blocking filter, reassemble the camera check the focusing if no problems your ok, if you get problems then google how to remove ir coating from the glass filter you have just removed then replace it.
I purchased a Canon SX130 IS and did exactly what i have described (no problems with focusing). I use a piece of floppy disk cut to the size of the lens and permanently taped on and i find it yields some awesome results. Google chdk and photoshop ir actions
Jun 04, 2013 | Canon PowerShot A495 Digital Camera
Triple colored ghosts
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Sony KP-43T90 43" Rear Projection...
Ghosting comes and goes
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 01, 2010 | Hitachi 50UX58B 50" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
How to upload photos and videos from sagem myx5-2v phone to my lap top using infra red
line up the infra red port (little black shiny square on phone, usually places on one of the edges.) with the computers infra red port(if it has one) then select picture on phone go to options, and send, choose Via infra red and select. the phone with now serch for an infra red device to send it to. when it has it will begin to send it. the receiving device should recognise that somthing is being sent to it and will request permission to recieve it. click ok and thats it. Ports have to be lined up exactly and very closely.
Nov 26, 2008 | Cell Phones
Red in picture creates a ghost picture
Sounds like a loose connection in the convergance amp ic's
Dec 10, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Blue, red and green ghosting, curves in picture
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 30, 2007 | Mitsubishi VS-45609 TV
EverFocus EHD730 Ultra 720 TVL Outdoor True Day/Night Camera with Logo
20 people viewed this question
Top EverFocus Cameras Experts
Steve
Are you an EverFocus Camera Expert? Answer questions, earn points and help others
