Question about Klipsch CA800TSW Speaker
How to hook up klipsch ca800tsw to right and left speakers ?
There is a strip on back of subwoofer with 2 + and 2 - connections.
CANNOT GET SOUND FROM THE KLIPSCHE SOUND BAR CONNECTED TO AN LG TV
If the sound bar has optical connection I would hook up to tv that way. I had to do that with my lg and sound bar. Hope this helps. Good Luck.
Mar 27, 2013 | Klipsch Power Bar Soundbar with Wireless...
My klipsck kw-100 subwoofer will not power up i,v checked fuse it,s not blown want migth i do next
u can eanny 1.5 volt battry ,get 2 length wire .strip both ends.stick 1 strip end in the speaker box on positive or red connector .then you do the same on the negetave or black connector .now you should have one strip end for positive one strip end for negetave now connect negetave to battry .then brush the positive wire to battry positive .if you hear a thumping sound that mean that your subwoofer is good if you dont hear eanny sound that mean it is dead.i have done this for the past 50 years.bye..
Apr 13, 2012 | Klipsch KW-100 Subwoofer Speaker
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
Clarion 9700RT (1990) car stereo. Color wiring codes for these wires: White, White w/black strip, grey, 2 green, 2 lavender the stereo is hooked up but just need to hook up wires!
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
These are the common colors for the radio.
Thanks
-david
Nov 10, 2010 | Car Audio & Video
I have the klipsch sub-10 subwoofer, making noise after use
it sounds like the sub is rubbing in the voice coil.
put the speaker in upside down to what it was before.
sometimes that extra bit of downward pull is enough to offset the error.
There are speaker reconing experts out there but it is cheaper to replace the sub itself.
the sub can be replaced for sure.
Jan 13, 2010 | Audio Players & Recorders
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
How to hook up speakers to emachine t3638? i have the klipsch 5.1 set
The EMachines T3638 comes with High Definition Audio support and you should be able to connect a 6 speaker system (1 subwoofer and 5 speakers).
I believe they are color coded as well. I believe the speaker set you are referring to is the Klipsch ProMedia Ultra 5.1. Is that correct?
Below is the a link to the connection instruction manual. It is a pdf document that you can print out. The instructions for installing the Speaker set is on pages 3 & 4 under Signal Connection and Speak Connection.
http://www.klipsch.com/media/products/owners-manuals/ULTRA51MANUAL_ENGLISH.pdf
It should be pretty straight forward, but send me a note if you have any questions about the process.
MO
Jul 13, 2008 | Computers & Internet
Klipsch subwoofer
its all about impedance matching...did you check to see that the new yamahas would drive from the system, before installing them? sounds like you will need to possibly add a matching transformer or other device on this one.
Mar 09, 2008 | Gem Sound SUB-650M Speaker
Klipsch subwoofer
how are you connecting the sub to you amplifier?
Dec 11, 2007 | Gem Sound SUB-650M Speaker
Klipsch CA800TSW Speaker Logo
50 people viewed this question
Top Klipsch Audio Players & Recorders Experts
rhodesworks
Tom Chichester
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
