Question about IBM ThinkPad T43 Notebook
Toshiba bios not starting
Toshiba bios not startin. i am trying to install a new operating sistem but i cannot enter the bios to set the primary boot device on the toshiba laptop...if I hit F2 it looks like it's trying to enter the bios but i waited 15 min. and it stood doing nothing. I tried other keys but not a chance.i tryed installing the new OP directly from windows but it sais that "no valid system partitions were found. setup is unable to continue" when i try to format any partition on my hard drive from start\run\cmd the command i type is "format C:\" or "format D:\" but it says invalid drive specifications.
please help. have a nice day
  • nebunel Jun 15, 2009
    how do I update the bios? my DVD rom it's on usb..i have no floppy...the intern dvd rom is not working...
    is this link goot for my toshiba? it's kind of old
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Download partition manager it`s free
http://www.partition-tool.com/personal.htm
and you can format,create ,resize etc your partitions...
BACKUP ALL DATA BEFORE MESSING WITH PARTITIONS!!!
update bios first just make sure it`s right model number(read instructions)
Posted on Jun 15, 2009
How to install windows 7 on toshiba satellite c50-a634
On the first screen you see on start up should ask "To enter setup press (ESC or DEL or F1). You need to know which key to depress to enter BIOS setup. Once you enter BIOS (Basic Input Output System you would need to setup your boot priority to your CD or DVD drive. Once you do that you will need to save your configuration and with your operating system disk in the disk drive restart your computer and then you will need to select Boot from CD or DVD, which ever type drive you have and your operating system setup should start.
GOOD LUCK!
Feb 19, 2014 | Computers & Internet
Booting up new motherboard
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
Jul 05, 2008 | ASUS P5PE-VM Motherboard
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Toshiba support
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb42&url=&dialogID=111194172&stateId=1%200%20111190763
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
I needed to change the hard disk of my computer. I installed the hard disk and tried to install the operating system which I have been using viz. windows XP pro. I inserted the operating system cd in the...
Hi
first go to the BIOS and check your Hard Disk is detected or not if it is detected then go to the boot section on your BIOS and set CD Room as a first boot device and HDD as a second...
or if your hard disk is not shown in the bios then check your hard disk reconnect power on you hard
disk.. and most important thing don't forget to check jumper setting of you hard disk...
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 06, 2011 | Computers & Internet
I need a bootable cc to reload xo or vista is na toshiba sattelie m55=s320 im having a hard time booting to start the installation and it wont run setup in dos .. whta can i do to serup from acd to run the...
windows xp and vista are self starting disks, you do not need any startu pdisks if you use these. you need to enter bios settings and change boot settings to selelct as primary boot your cd-rom and this will solve you rproblem.
Jul 20, 2010 | Computers & Internet
I have a dell latitude L400 which has external DVD Rom. I have bought new hard drive and traing to install new window but the sistem sais that The operating sistem is not found. F2 and F12 kis are not...
With a new hard drive you have to first format and install an operating system before it will work. Insert the hard Drive and connect up the DVD, set system BIOS to Boot from removable media IE: The DVD, and insert a Windows setup CD/DVD in the DVD drive, boot of that DVD, and proceed with the install following the instructions. That will install a Windows operating system.
Feb 18, 2010 | Computers & Internet
Can't install new OS
you need to install directly from the vista disc when the computer is powered on, put the disk in and it should ask you to press any button to start from cd..
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first. the computer should say what button to press to enter bios or cmos or setup when its turned on
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
ones you get into the vista setup you can empty the hard drive, getting rid of windows xp and then install windows vista over it.
Let me know how that goes,
Thanks,
Ekse
Jun 03, 2009 | Toshiba Portege R100 Notebook
Sony laptop won't detect hard drive
If the drive hasn't been formatted, that is normal. On some systems, you also have to force the BIOS to recognize the drive by entering the BIOS setup (check with Sony or manual to learn the key needed). Once you know the proper key to tap at power on (it varies, sometimes F1, F2, Esc - who knows?), you will be presented with a simple text screen with a number of different selectable items. Choose 'Set factory defaults' and the BIOS should look for the drive and set the parameters for you. If that still doesn't work, check through the other BIOS items and you should find 'Detect fixed (or hard) drive.'
Sometimes installing a larger drive than the original can cause problems and if the BIOS is older, it may set the drive parameters of the original drive and ignore the excess capacity.
Mar 01, 2009 | Sony VAIO K15 Notebook
Problem in reinstallins operating system
This can be started by changing the boot order of your system.
To do so, start up the laptop from a shutdown stance.
This part requires some speed, it will either require the "F2", or "F10" in most cases. IIts not 100% guarantee that this will be the two buttons required for activation of your bios.
WARNING: BE VERY CAREFUL IN THE BIOS. YOU CAN FOUL YOUR COMPUTER VERY EASILY BY CHANGING THE WRONG SETTINGS IN THE BIOS.
When you enter the bios, try to find the boot settings. And make sure your cd-rom is selected as the primary boot device.
After you change the cd-rom as the primary device, Save and Exit from the bios and your computer will automatically restart.
Make sure the O.S. (Operating System) CD is in the CD-ROM and it should automatically boot from the cd-rom, it may come up with options, your options should await you when or if the auto boot from cd works.
Hope this helps.
Oct 22, 2008 | Computers & Internet
I need Help
Hi Banyar, lets check the main menu & the boot order in you're bios. Start up the PC, as soon as you see any display on the monitor press the delete key every 2 seconds until the bios main menu loads. This is also where you can see the time & date. List on the left is;
Primary IDE Master
Primary IDE Slave
Secondary IDE Master
Secondary IDE Slave
Across from these on the right is the matching device. If you have one hard drive the bios will show its model number on the right.
Ex: ST150322A. (You're drive will be different). If you have more than one hard drive the second drive, (Should be listed as Primary IDE Slave). CD-ROM drives would be listed as, Secondary IDE Master & Secondary IDE Slave. Write down the model name of the Primary IDE Master on paper. Now go to the title, "Boot" in the bios. Use you're manual & go to page 2-25. High-light, Boot Device Priority & press enter. Set the order as shown in the manual. Make sure the 3rd boot device is set to the correct hard drive listed from the main menu. The model you wrote down. Once set save & exit the bios. The PC will restart. You should no longer receive the error message & windows should boot normally. If windows does not load normally than it is possible that the Primary IDE master drive is not the drive with windows installed on it. You must find the correct drive with windows loaded on it. Connect that drive to the Primary IDE master port.
You may need to reset the drive’s pin settings so it is seen as the primary drive.
Than change the 3rd device in the bios boot priority list with the correct drive. Windows demands that the operating system be located on the, Primary IDE master port. Please read pages 2-12 & the top of 2-13 in you're manual.
More questions? Post them here.
Good Luck!
Mike
Jun 21, 2008 | ASUS P5VD2-MX SE Motherboard
IBM ThinkPad T43 Notebook Logo
129 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
