Question about KitchenAid 30" Gas Architect Series Ii Cooktop - Kfgs306vss
Electrode center burner will not light
One of burners can not ignite only having clicking sound.
First you need to brush out the end tip of the sparking electrode and the burner metal part facing the electrode so they can create a spark. If not any result the you should remove electrode and check if the ceramic cover is broken and the sparking goes in wrong way and you will need to replace it.
Sep 10, 2011 | Jenn-Air JGC8430 Gas Cooktop
When the burners come on the electrode keeps clicking. If I unplug it I can light it manually
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Mar 28, 2011 | Cooktops
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Aug 26, 2009 | Miele 35 in. KM326G Gas Cooktop
Viking stove right burners won't light
can u see the burner spark if not then ht lead at fault of electrode
Aug 21, 2009 | Viking 31 in. VGSU101 Gas Cooktop
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
Burners won't light
remove hte buerner cap and with a nail file or emory clloth try cleaning the electrode(sparker), sometimes a build up of carbon onthem will prevent proper lighting, also lool for cracks in electrode itself,if ther cracked they wont be very effective and need replacing
Feb 27, 2008 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
KitchenAid 30" Gas Architect Series Ii Cooktop - Kfgs306vss Logo
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
