Question about Fujitsu Fi6130z Sheetfed Scanner
Line on scan - Fujitsu Fi6130z Sheetfed Scanner
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
My epson stylus nx105 shows a black vertical line when scanning but not printing
THE BLACK SCANNED LINE IS PROBLEM OF THE SCANNER CARRIAGE AND HAVE TO BE CHANGE.
May 18, 2014 | Epson Stylus Photo R300 InkJet Printer
AUTOMATIC FEEDER LEAVING LINE ON SCANNED PRINT-OUT
clean the thin DF glass strip on the left side with a damp cloth
Mar 15, 2010 | Brother MFC 6490CW InkJet Printer
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
Line through scanned document when using the document feeder only
try cleaning the glass scan bar on the unit with a clean soft cloth.
Feb 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Line in scanned item
Is the line in the same location everytime? Then the there is dust on the glass. If it keeps shifting, wipe the photographs before scanning. If the line appears same thickness at the same location, may be the scan module is damaged, but this is generally rare.
S. Mohan. Chennai, India
Feb 04, 2009 | Epson Expression 800 Flatbed Scanner
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
Television display
In basic terms TV images are made up of hundreds of horizontal lines, with interlaced scan it will display in order line 1, 3, 5, 7 and so on and once it reaches the end it will fill in the missing lines 2, 4, 6 and so on until it starts again.
For progressive scan it will display the lines in order 1, 2, 3, 4, 5 etc.
cheers
Jan 21, 2008 | Televison & Video
Lines showing up on document after scanned
Do you have lines, too when scanning a document?
In this case the scanner glas needs cleaning. Use a soft cloth and some glass cleaning solution and wipe the scanner glass. The lines should disappear.
Nov 12, 2007 | Brother MFC-3240C All-In-One InkJet...
Fujitsu Fi6130z Sheetfed Scanner Logo
19 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Jax Planet
Jax Planet
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
