Question about IBM Thinkpad 600 System Board Motherboard
What is error 00173, 00192, and 00163
With this report om screen, the system refuse to boot any further
  • RescueTechLA
    RescueTechLA May 11, 2010
    Can you boot into Safe Mode?
  • IBM Master
  • 4,806 Answers
Error 192 means a fan error, to test this measure the voltage of the backup battery. If the
voltage is not correct, replace the backup battery. Check the fan and the system board.
Error 163 means the time and date is not set, to set the time and date hit F1 when you see the IBM logo and set the time and date.
Error 173 means the configuration data is lost, to sort that select OK in the error screen and set the time and date.
In most case its the CMOS battery that's run low and need to be changed for a new one, so for the time being you will have to keep setting the time and date and it will boot to windows.
Good luck
Posted on Jun 15, 2009
My zinox E11IS1 has recently refused to boot. I powered the system for use and it hanged at the first Zinox logo screen and will not go further. I tried formatting and re-installing the OS but it still...
There is possibly an underlying issue with your laptop.
Is your hard drive ok?
Test the memory
Take it into a repair shop if you do not know how to do any of the above!
Mar 14, 2015 | Computers & Internet
How do i cancel magazine subcriptions?
Usually They Will Not Cancel Until Time Period Is Up--If They Don't, Refuse Any Further Payment And Contact BBB
Feb 27, 2015 | TI Media Solutions PEOPLE Celeb News
How do I Install updates for Microsoft Essentials if the Essentials Programm this refuse?
Normally Microsoft Essentials automatically updates itself along with other automatic updates to other parts of your Operating System (in your case, Windows Vista). But it sounds like there is something wrong here with your automatic settings. At the end of this advice, there will be a link to follow to give you the exact directions to follow to hopefully fix your problem. Once you get to the page this link will send you to, click on the link (in blue letters) that say "How to perform a clean boot." You will now see a circle with a dash in it and "How to perform a clean boot" inside a blue border. A bit further down you will see "Windows 7 and Windows Vista" in blue letters. Follow those directions and it should fix your problem. (Where it states that you might need "administrators rights," don't worry. Unless your computer was set-up with a specific administrator, YOU already have those rights.
Remember, follow the directions including following the links further down the same page. They are: "What is next when I have a clean boot environment" and "How to reset the computer to start normally after clean boot troubleshooting."
Another piece of advice - Print out ALL 3 sets of instructions before starting this procedure.
Nov 28, 2014 | Acer Aspire Computers & Internet
Windows Error Reporting Error
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 30, 2012 | Computers & Internet
Acer Aspire One D255e shows blancco hardware report on boot and locks up, what is the problem here?
Problem:Your HDD has been formatted using a tool called "Blancco Erasure" which creates detailed IT hardware report after the erase process.
Solution:boot into dos from any bootable cd\dvd (or connect this drive as a slave with other master booting drive and format using this command "Drive letter:\ fdisk /mbr "
Mohammed Abd ElAziz Youssuf
Sep 02, 2012 | Acer Aspire One D255E13438 Netbook
My computer is unable to boot in any of the options, what do i do?
Booting problems with your laptop occur when the computer gets infected by a virus or when there are underlying hardware problems.You can use several troubleshooting techniques before taking the laptop to a service center for repair.
1. Turn on the laptop without pressing the power button too long, to prevent it from turning on and then turning off. Also make sure that the laptop has enough battery power to boot up.
2. Unplug any external drives connected to the computer. These include flash drives, external hard drives or any CD or DVD in the optical drive. Listen closely as you boot the computer. If the laptop is emitting ticking sounds and refuses to boot up at all, the hard drive or another internal component may be damaged. Consider bringing your laptop to a service center.
3. Turn on your computer and boot to "Safe Mode" or "Last known good configuration" if the computer powers on but displays an error before it boots the operating system. If this is the case, the laptop may be infected with a virus.
4. Use the "System Restore" feature in Windows to restore the operating system to an earlier time. Note, however, that this will not work for those whose computers have the "System Restore" feature disabled. Click "Start," "All Programs," "Accessories," "System Tools," and then "System Restore." When the dialog box appears, click on the box for "Restore my computer to an earlier time," and then "Next." Select the restore point that you want and follow further instructions.
5. Resolve a "blue screen" problem. This error screen appears before booting, and is caused by several factors such as virus infection or hardware failure. Read the error message to determine what factor caused the problem. The error message should include troubleshooting tips.
6. Consider repairing the operating system if the computer does not boot at all. This procedure will repair the operating system without erasing your data and settings. Access the Resource list for instructions on how to repair Windows.
I hope you find it very helpful. Thank you for using fixya.
Aug 15, 2011 | Computers & Internet
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
Parasitic draw on battery how to check on car with all those electronics still live with ignition key out of ignition lock
You will be able to help diagnose the problem by pulling fuses. Take a volt meter and put it to oms. Disconnect the positive battery cable. Put one end on the positive battery termanal and the other on the cable. Note the oms. Now, pull one fuze at a time until the oms drop considerably lower than before you pulled the fuzes. Thats the system that is drawing the power. Once you know the system you can track it down further. It could also be your altrenator. Disconnect it too and measure the oms before and after. take your time and do one system at a time noting the oms before and the oms after. My quickest guess it it is either your altrenator or your radio. Please note, you will have some "draw" no matter what because your clock radio or door lights will draw power. If you want to see this, test the oms with the doors closed and then test with the door open. The oms number will be higher with the door open.
If you don't have a volt meter, you can always test one fuze at a time over night. That would take considerably longer tho.
Dec 07, 2010 | 1994 Lexus LS 400
Hi I work at a school and have had several convergence machines refuse to boot up. It takes me to the "safe mode etc." option screen but then idlessays monitor sleeping then tries again to boot and goes...
that happens because you have operating system problems, even in safe mode go to the start menu and chose restore system to a previous date when the computer was working fine
Jun 12, 2010 | Computers & Internet
My acer refuse to boot and it not battry problem.
reset ur bios
take out ur batt. and unplugg
then short out the batt. terminals
all at once on the computer
then try again
May 12, 2010 | Audio Players & Recorders
IBM Thinkpad 600 System Board Motherboard Logo
1,133 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
