Question about Tti BH20090 Hoover Presto 2-in-1 Cordless Stick Vac
Hoover presto won't charge
The vacuum no longer charges
Dyson 45 is no longer charging
Most likely your battery needs to be replaced.
It's probably doing a "false charge", it's like having a rechargeable D-cell but internally only the equivalent of a AAAA-cell is working, only a more extreme version of this situation.
It would charge up very quickly but also discharge very quickly and not really power anything.
The charger doesn't realize that it's only taking seconds to charge the battery, it's just checking if the voltage is up to a full charge level.
Sep 06, 2016 | Dyson Vacuums
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ā€ˇReview by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
When battery has been fully charged, the charge only lasts 1/2 hour before it needs to be re-charged.
I would assume that the battery is old. With time batteries looses a bit of charge, and their life get worse. You should just buy a new battery and the device will work longer for sure.
Oct 19, 2015 | Shark SV1106 Navigator Cordless Upright...
My hoover presto vacuum wont charge
Either the charger or battery is defective.
Mar 23, 2015 | Hoover Vacuums
Will not charge
Wild guess, Contacts for the charge function are dirty, blocked with hair or battery is past it's prime. How old? Owner's manual? Troubleshooting section?
Mar 04, 2015 | Dyson Dc34 Animal Handheld Vacuum With...
Hand vac doesn't hold power
Mostly likely it needs a new power pack, but you could try cleaning off the contacts first. Use a pencil eraser and clean the metal power contact on the charging unit and the vacuum. Then charge it over night. If that doesn't help, charge the power pack.
Oct 15, 2014 | Dirt Devil Gator 18V Cordless Hand Vacuum...
Hoover linx
How old is your battery? and did you keep it on charge when it was not in use?
Most rechargeable batteries require a spindown, where as you completely discharge the battery before recharging it again.
I know you aren't wanting to hear this but in all probability that battery is spent and will need to be reconditioned at a battery place, however, it will cost almost as much as a new one it would be your call.
if you have a ohm/volt meter it might be possible to look at the charger and get a volt/amp reading and then test it see if it is putting out the proper voltage it could be putting out a trickle charge and it would take forever to charge it.
there is one other situation to look at and if the beater brush or motor is causing a resistance it will pull a battery down quick.
I do not own this vaccum so I can only guess as to the possibilities.
Jul 02, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Where is battery compartment
Hey Ashish,
I have attached a link to the users manual for your Hoover vacuum. You can find a diagram showing where the battery is on your unit and where the charging port is.
http://hoover.com/file/341/
You can purchase replacement filters direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jan 23, 2014 | Hoover Presto Stick Vac, BH20095
I have a 4.5 year old IRobot Roomba 530 Robotic Vacuum. Appears to be fully charged but then only runs for about 30 seconds before stopping. What may be the problem?
You need a new battery - they don't hold their charge after a while. There is a lot of advice on line about how to try to make the battery last longer but 4.5 years is actually pretty good.
Sep 02, 2013 | iRobot Roomba 530 Robotic Vacuum
Tti BH20090 Hoover Presto 2-in-1 Cordless Stick Vac Logo
753 people viewed this question
Top Tti Vacuums Experts
JoeVacs
Are you a Tti Vacuum Expert? Answer questions, earn points and help others
