Question about Orbit Hydro-Rain HRC-100-04-NA 4 Station Ind/Out Controller
Hydro Rain hrc 100 says NO AC
My Hydro Rain 100 is not working and there is a NO AC message on the screen.
    Problem Solver:
  • 6 Answers
You have a possibility of four things going on here.
1. no power at the outlet (check the breaker or GFCI)
2. burned out fuse in the controller. (small glass tube in back)
3. burned out transformer (the thing that plugs into the wall)
4. your clock got hit by a voltage surge (lightning) and is, for all intents and purposes, dead.
The solution to the wall outlet is either a breaker, or GFCI reset, or call an electrician.
The solution to the others is:
All the items are available at your local irrigation supply house, (or even online) The plug-in type 24VAC transformer, the glass fuse, or even a new clock, though it MIGHT be time to purchase a new one.
Posted on May 19, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 71 Answers
Could be many problems with a description as vague as "not working." Can you be more specific? Does no water come on? Does the timer say it is operating? Is it plugged in? Does outlet have power? Are wires connected correctly? Can you start a zone using the bleeder screw?
Posted on Apr 10, 2014
Unable to get wi-fi to kick in and hold for a call. although it works just fine in store.
Troubleshoot issues related to data connectivity and your ...
support.sprint.com/...Kyocera.../WTroubleshootingGu...
Sprint CorporationThis article helps you troubleshoot data connectivity issues on your Kyocera Rise. You may have data connectivity issues if you're unable to: ... Some features and applications require a data connection to work properly. ... Note: Most Wi-Fi networkshave a range of less than 100 feet indoors and up to 300 feet ... Contact us ...
Troubleshoot issues related to your Kyocera Hydro Edge ...
support.sprint.com/...Kyocera.../WTrendTroubleshoot...
Sprint CorporationThis article helps troubleshoot your Kyocera Hydro Edge slowing, freezing, ... You mayhave performance issues if your device: ... back on; Displays error messages; Isunable to install or update applications ... Press and hold the Power key, tap Power off, and then tap OK to turn your Kyocera Hydro Edge™ off. ... Contact us ...
Brigadier by Kyocera Support ' Verizon Wireless
www.verizonwireless.com/support/brigadier/
Verizon Wireless
Dec 13, 2015 | Kyocera Cell Phones
Why does on my hydro rain timer it says power off when its still plugged in? non of the sprinklers go on
Hi
Diconnect all power to unit this allows the unit to reset includes battery .After reset check/you may have a shrt circurt in the systen
Aug 19, 2014 | Orbit Hydro-Rain HRM-100-03-BD HRM 100...
How do I get my text messages transfered to my laptop so I can print them off? I have a kyocera hudro
. Download BackupTrans Software's "Android SMS + MMS Transfer" software .It help us extracts SMS and MMS messages from any Android device and stores them on the PC.
2. Connect your Kyocera Hydro to your PC via mini USB cable. "Android SMS + MMS Transfer" will scan your drive and create a list that it can sync to your computer.
3. Click on "Kyocera Hydro" under the list of devices in the left-hand panel of the software.
Select the messages from the list, click "File" -"Print SMS and MMS." Select your printer and then click "Print."
App Option
4. Press the "Home" button on the Kyocera Hydro.Tap the "Google Play" icon to open the application market. Search for "PrinterShare Mobile Print." Tap "Install" to download and install the software.
5. Both the printer and the phone need to be on the same wireless network.Tap the app to searches the network for the printer.
6. Tap "Messages" to open your SMS and MMS messages in PrinterShare. Select the wireless printer.
Manual Method
7. Click on the messages and then tap"Copy message text".
8. Return to your Home screen and then open the email app.Compose a new message to yourself and paste the messages you want to print.Tap"Send".
9. Open the email on any computer connected to a printer and then click "File," and choose "Print".
10. Then you have successfully print your message from Kyocera Hydro.
Aug 12, 2014 | Boost Mobile Kyocera Hydro Smartphone
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Our rain bird was off and i changed the battery. I tried to turn it on manually and it says, no ac?
The battery only holds the program in the memory. The No AC message tells you that the AC power that is supposed to operate the valves is not getting to the control unit. Someplace there is a power cord with a transformer that is taking the house current at 120V and powering the unit. Something has been disconnected or a circuit breaker is tripped. If there is an outside socket with a GFI in it, try resetting it.
Paul
Sep 17, 2010 | Rain Bird Xerigation XCZ-075
My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
Orbit Hydro-Rain HRC-100-04-NA 4 Station Ind/Out Controller Logo
910 people viewed this question
Top Orbit Garden Experts
squeely
richie46
Are you an Orbit Garden Expert? Answer questions, earn points and help others
