Question about angieslist.com
Cleaning AC vents and ducts
Need good contractor for cleaning AC vents and ducts.
    Master:
  • 409 Answers
If you are in the market for an air duct cleaning check out Air Duct Cleaning.
Posted on Apr 21, 2016
Dryer wont heat up
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Apr 08, 2014 | Samsung DV448AEE Electric Dryer
Electric dryer duct fire
I think this question must have been misclassified, as it states that this is regarding a Problem with Whirlpool Cabrio WTW6600SBT Top Load Washer. I will assume this is about your dryer. Dryer fires are not as uncommon as most would believe. It sounds like you were utilizing the nylon or plastic dryer vent hose. The lint in your dryer that accumulates can catch fire after years of use. A good dryer vent cleaning will cover your vent duct from the wall to the vent exit outside the home. You should have this cleaned by a professional and have an internal dryer cleaning conducted. If funds are tight, you can do this yourself by pulling the dryer out and running the vacuum cleaner extension into the dryer vent opening after you remove the melted hose. Just be careful when pushing the hose extension up the exhaust as some models will have a heating element in line. If you feel any resistance, that is when you stop pushing the hose in and just suck any lint you can from that point. This is a good start, but a good full internal cleaning of your dryer is warranted. Make sure you unplug the dryer before attempting any cleaning or servicing. Safety first!
Feb 19, 2014 | Dryers
No air at vent
Sound like you need to replace the heating element.
Jan 01, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
Mar 17, 2013 | Maytag Neptune Dryers
Need illustration of vent system ducting
If you want to do a good job you are going to have to pull the dash. Once it's out you will see every thing.
May 25, 2010 | 2009 Toyota RAV4
Dryer says check filter and it is clean
Air flow in the duct work is restricted... and the dryer sensor thinks that the filter is clogged.
You will need to take a fluffy cleaning wand and, with the filter removed, try loosening up some of the accumulated line in the duct.
Next, remove the lint pipe from the wall connector and try cleaning it and the pipe for as much distance as you can reach.
Finally, go outside and check the vent. It needs to be clean and clear of obstructions... also, needs to close when the machine is off.
You can do testing on the outside vent with "air dry" setting - hot air is not required... Keep cleaning ductwork until the outside vent passes air freely.
After air flow is restored, the sensor in the "VENT" alarm will act nice.....and stay off
Nov 01, 2009 | LG DLE2514 Electric Dryer
Clothes not drying proparley
, your vent duct is probably obstructed (it happens over time). If your model is the type where you could feel air if you removed the lint trap, do so and turn the dryer on. If you get warm air there, you know it is in the ducting, in the back of the machine, or at the wall vent. Pull off your duct, and give it a good cleaning. Clean out the back of the machine, and the wall vent. When you reinstall the ducting, minimize any twists and turns possible.
If the coils are good, but you get no heat, the problem may be the thermostat or the switch.
Aug 14, 2009 | Candy Washing Machines
My dryer turns, but it doesn't dry my clothes. After drying several time they are still damp
, your vent duct is probably obstructed (it happens over time). If your model is the type where you could feel air if you removed the lint trap, do so and turn the dryer on. If you get warm air there... you know it is in the ducting, in the back of the machine, or at the wall vent. Pull off your duct, and give it a good cleaning. Clean out the back of the machine, and the wall vent. When you reinstall the ducting, minimize any twists and turns possible.
If the coils are good, but you get no heat, the problem may be the thermostat or the motor switch.
Aug 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Cleaning the Air Vent
you can take it all apart and clean it by hand, or take the cap off the outside and use a leaf blower to push out all the build up
Jul 17, 2009 | Bosch Axxis WTA 3510 Electric Dryer
angieslist.com Logo
55 people viewed this question
Top angieslist.com Computers & Internet Experts
David Payne
David Payne
Are you an angieslist.com Computer and Internet Expert? Answer questions, earn points and help others
