Question about Sony Handycam DCR-TRV145 Digital Camcorder
Ezcap Ver.36.1S I have ezcap USB2.0 Video capture on Windows 7 but cannot get any sound on recorded video, can you help please
lim_skylp
SOURCE: Unable to detect video camera recorder (SONY DCR-HC20E)
this nice thank you
Posted on Mar 08, 2009
  • 497 Answers
SOURCE: cannot capture video
Option 1:
(Applicable for Windows XP Operating System only):
As you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Option 2:
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Good Luck!!!!!!!!!!!!!!!!!!!!
Posted on Sep 23, 2009
SOURCE: Camera Sony DCR-TRV145E and software compatibility with Windows 7
j'ai un problème de demarrage de caméra. affiche toujours "system infolithium"
Posted on Mar 09, 2010
SOURCE: sony 560x digital zoom video capture problem
i cant export my video from my digital camera sony 560x
Posted on Apr 06, 2010
  • 182 Answers
SOURCE: Windows 7 does not recognise imagemixer 1.5 for my
Yes its not compatible (with windows 7 and vista)
Please upgrade to Picture Motion Browser Software version 4.3.02
Please download it from following link:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4753&SMB=YES
Bingo !!! problem solved
Posted on Aug 02, 2010
Tip
For better video quality with EasyCap USB video capture card:
1. Install FFDShow codecs to Your Windows: http://adf.ly/1310198/ffdshow-codecs
2. Use gold plated cables and adapters - s-video is normally a little bit better than composite
3. Check that all contacts between devices, cables and adapters are tight enough
4. Do not use any extension USB cable - put EasyCap/EzCAP straight to the computer's USB port
5. Switch off all other programs during capturing
6. Capture with max resolution 720x576px PAL, 720x480px NTSC.
7. You must have a powerful computer - check that CPU Usage is under 50% during
capturing and if it goes over, so buy more RAM and/or better processor and/or
better graphic card and/or faster hard drive.
on Mar 13, 2014 | DekCell EasyCap USB 20 Video Capture...
Video capture ezcap ver36.1s
I had the same problem. I attempted to solve it by using two EZYcaps with the idea of splitting the sound and video streams but as they use the same driver that didn't work. Splitting the video and sound inputs to two USB ports is the key to success. What did work was when I tried plugging in an old USB SoundBlaster sound stick. It is a little thing like a thumb drive but with two mini jacks, one for mic and one for earphones. I plug the mic into the SoundBlaster and the S-Video into the EzyCap. As the SoundBlaster uses a different driver they don't clash.
I also use "SplitCam" to put it all back together and stream the whole lot to the internet. Split Cam also lets me stream to inSpeak video chat while I also stream to Livestream. check out the results on www bgemc.org site. The second EzyCap sits as a spare in my bag. I also audio record the service at the same time. This is all done through a Toshiba Satellite laptop. CPU usage is usually below 30% often down to 10%. By the way I used to use ManyCAM and U-Stream but didn't get good results. All the best. Malachi.
Mar 28, 2014 | bessac.ca Ezcap USB 2.0 Video TV DVD VHS...
Video capturing problem
I first got the Elgato Video Capture device for my Mac, I was hard-pressed to find any info on the initial problem I was having of trying to see what I was recording while playing my NES. All of the posts on forums were from years ago, and none of them helped me out at all.
Hopefully I can help out someone who has the same problem, and maybe make their life a little easier while trying to capture their NES footage.
Dec 19, 2013 | Arcsoft ShowBiz DVD 2 (3265)
My ezcap116 is not picking up video or audio from my xbox 360 when i go on arcsoft showbiz 3.5
what you need to do is make sure your connected with everything here is a website on how to set up your capture card easily. You will need 3 female splitters and 2 tri-colored rca sockets all male on both ends Red White and Yellow.
http://www.ezcap.tv/guide.html
Here is the URL if it doesn't help I'm sorry and you may have to get a different capcard or get a computer that supports windows 7 32/64 bit.
Dec 04, 2010 | Sony EzCAP116 USB 20 Video Capture Device...
Sony Handycam DCR-TRV145 Digital Camcorder Logo
103 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
