Question about Mainstays Corner Desk, Multiple Colors
Asembly where do the 2 triangle pieces that seem to have no place in the instructions go
In a 4'x 4' square, cut into 2 triangles, what would be the 3rd side of each triangle?
Hi Carolyn
This is easy peasy.
A squared plus B squared = C squared
So, 4 squared (16) + 4 squared (16)= C squared
C= square root of 32 or 5.66
Link below provides a calculator so you can do it yourself.
-Steve
right triangle formula Google Search
Mar 12, 2015 | Computers & Internet
How do i asemble a 280 dt izuzu motor
This question seems beyond the scope of this website. Break down and buy a shop manual to get full instructions, torque values, pictures, etc.
Dec 08, 2014 | Isuzu Cars & Trucks
Cartridges will not engage
Check on the left hand side where the cartridge slides in there is a small swivelling retaining triangle of plastic that is lifted up by a thin plastic rod (hidden) when the front door is opened. if this triangle becomes detached from the hidden operating rod then that cartridge will not lock in. the problem appears to be on the right side but it is this left triangle causing the problem.
simply locate the small plastic triangle and attach a 6 inch piece of scellotape to the triangle so you lift it up to allow the cartridge to slide and lock in place. then give the scellotape a sharp tug and it will come free and the small locking triangle will drop down in place and the cartridge is locked.
Nov 11, 2012 | HP LaserJet 3600n Printer
There is an equilateral triangle. in it there are three coins of equal radius is placed. find the radius of the coin.
how big is the triangle? if the coins are a mile in diameter doesnt mean you cant have an equilateral triangle with legs of 32 miles long.
or are you asking for the equation?
i will send you on the path to the equation.
if you draw a circle on a piece of paper then draw a triangle around it where is the center? if the triangle were a perfect equilateral then the circle would be a perfect circle touching the sides of the triangle.
its important to know where the center is because the center of the circle to the edge of the circle is the radius.
so the center of a triangle is the center of the circle. therfeore the radius of the circle will equal hieght/2...
thinking that way you can say that if there were three coins then the center of the triangle cant be occupied by a coin but is very close to an edge. where is the center of the coin?
Jun 10, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
How to access fasteners for the sideview mirror
Most of the time it snaps into place. There are metal clips that slide on to the plastic triangle that then fit into a slot on the door it's self.. Also look for possibly one screw holding it in place..Some will have those clips on the bottom of the triangle and the triangle will slide up toward the roof of the vehicle. Be careful because you don't want to break the triangle piece
Feb 26, 2010 | 2000 Nissan Sentra
Need asembly instruction for workmate wm550
If you are in Australia get in touch with Bunnings and they should be able to either help you or point you in the right direction. Failing that see if you know the maker then look up their website just use theirname.com
Good Luck
Sep 07, 2009 | Hand Tools
Need instructions to install replacement side view mirrors for 95 chevy blazer
You will have to remove the door panel, behind the triangle piece on the top right of the drivers side door panel you will see 3 nuts which hold the mirror in place. Remove the nuts and the mirror should come right off the door. Same on the passenger side.
Jun 03, 2009 | 1995 Chevrolet Blazer
My new reebok i bike has arrived without asembly instructions
http://www.reebokfitness.co.uk/index.php?id=3&L=2
The above links to the reebok website where they have pdf copies of all manuals for their exercise bikes and computer parts - ibike and its computer is there.
Mar 14, 2009 | Reebok Exercise & Fitness
Wont spin
I had this same problem once and it was pretty simple, I removed the agitator asembly, not 100% sure on your model. and there is a cupling between the moror and the agitotor. the guy at the appliance store saidit was a sacraficial part that brakes when a large load is put on the motor to protect it. usually like a 13.00 piece
Feb 18, 2009 | Whirlpool LSR8233J
Mainstays Corner Desk, Multiple Colors Logo
Top Mainstays Furniture Experts
ray gallant
R.A. Ellis
R.A. Ellis
Are you a Mainstays Furniture Expert? Answer questions, earn points and help others
