Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Rumbling sound from the back
Rumbling sound coming from the back
What might be experienced by transaxil/transmission bearings wear? Rumbling or vibrations?
Kia is bad with wheel bearings ;.About 80 to 100k they start going bad. You have to check them physically with a dial gauge or know how to inspect them in other manners. They cause a rumbling sound when they start to go bad.
Feb 01, 2015 | 2007 Kia Amanti Sedan
2004 ford freestar rumbling noise as I drive down the road at about 45-60mph - it sounds and feels a bit like I hit a rumble strip but it is coming from the engine
Sounds like a half shaft. Reach around behind each wheel and see if there is play in the shaft that leads from the wheel to the transmission. There should be no play. Other possibility is a bearing hub. Jack up car, grab the tire at 9 and 3 o'clock. Shake wheel if there is movement not from the tie rod then it is the bearing hub.
Jan 24, 2014 | Ford Freestar Cars & Trucks
I have a kitchen aid khms 1850 microwave. When setting idle it continues to make a small rumbling sound and after 30 minutes it smells like something is overheated. I'll unplug it after a day and will...
That is the sound of the magnetron failing. The large capacitor inside may also be drying up and causing the sound. When the capacitor dries up further it will start blowing fuses.
Nov 24, 2013 | Microwave Ovens
I get a rather loud rumbling sound when I first start up the dryer the drum is turning but still getting the rumbling sound but not as loud.
Sounds like you need rear rollers or you have a bad blower wheel. If you turn the dryer off and still hear the rumble for a few seconds its the blower wheel. If the rumbling stops instantly then you have bad rear rollers. Hope this helps.
_MJ_
Dec 14, 2010 | Maytag Dryers
My dryer rumbles when it is spinning. But it also
The drum support rollers are worn. This will cause loose belt tension and a rumbling sound. You will need to pull the drum to find the rollers at the lower back of the drum. Check the roller shafts for wear and replace them at the same time as the rollers if needed. Check the belt and tensioner for wear before reassembly. This should fix ya...
May 08, 2010 | Dryers
Shaking really bad and rumbling sounds/ really slow
i'd bet the catalytic converter is stopped up.
Feb 03, 2010 | 1991 Chevrolet Corsica
Rumbling noise on a low speed between 25-40 miles
Does it sound like an exhaust pipe hitting the floor, or is it a different sound?
Aug 01, 2009 | 2006 Saturn Vue
Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
May 30, 2017 | Haier HSA04WNC Compact Refrigerator
Rumbling sound
It sounds to me like you have a bearing going out in one of the rear wheels. Get it fixed soon. It's pretty pricey but it will cause a lot more problems if left unchecked.
Jan 05, 2009 | 2000 Toyota Corolla
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
16 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
