Question about Dell 1409X DLP Projector
Replace dlp chip
Help to replace
What is the correct part# for a DLP: Mitsubishi WD60737 60", Serial#139599 Made June 2009?
If your set worked well (no lines, maybe only white or black scattered pixels) before you replaced the DLP chip, then your problem could be that the DLP chip did not get seated properly or the cam screws were not tightened enough after replacing the chip. The DLP chip must be seated properly in its socket or else line and column lines will be seen. There is also the possibility that the DLP chip is defective or suffered static damage while being handled during the installation. Hope this helps.
Jul 11, 2016 | Mitsubishi WD Televison & Video
Can I diagonally adjust (clockwise/counterclockwise) my Mitsubishi DLP TV? The picture is off center
You need to align the optics mechanically. If you changed the dlp chip and its not centered then the chip is not shimmed properly or the reflection mirror behind the lens needs adjustment. You should get a service manual for that chassis and follow the directions. there may be an electronic method but I am not aware of one.
Sep 05, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Dlp chip replacement
1910-6003 Does not look like a good part#
The correct part# 276P595010 Dlp 1910-6143W
www.aaatvservice.com
Aug 14, 2014 | Mitsubishi WD-60735 Projection Television
After replacing the dlp chip in my mitsubishi tv there are vertical lines on the screen. any ideas?
i had the same lines on my 65' mitsubishi tv after replacing the DLP chip. after going back over everything i realized that the casinf that holds the chip in was not in the lock position. i took the chip out and replaced it then turned the little locking mechanism to the locked position. now my screen is perfect. hope this helps.
Nov 21, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
We just replaced the DLP chip in our mitsubishi 1080P tv because we had white spots all over the screen. Now after replacing the DLP chip we have no picture at all but we have sound. Help?
Likely you either forgot to reattach your color wheel ribbon connector, or have it on upside down. It's the tiny ribbon cable behind your circuit board that will come off as you pull the board away from the DLP chip.
Aug 18, 2012 | Mitsubishi WD-60735 Projection Television
White death DLP TV
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Jun 04, 2012 | Mitsubishi Televison & Video
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Dell 1409X DLP Projector Logo
42 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
