Question about Eureka Mighty Mite 3670 Bagged Canister Vacuum
My eureka 3670 seems like its working but has almost no suction. any advice appreciated!
Almost no suction on my eureka 3670 mity mite?
Posted on Nov 17, 2009
Why doesn't suction work on eureka
The hoses may be clear but debris could be clogging the point where it is discharged into the bag or container. There also could be a debris clog at the intake.
Sep 03, 2014 | Eureka Vacuums
Eureka optima 431 brush motor works but suction motor doesn't
Hi Patricia, it's Jack at Dyson.
It doesn't look like your question is about a Dyson vacuum. You might like to resubmit it under the correct category to be sure of some helpful advice.
Feb 06, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Eureka Mighty Mite 3670 Bagged Canister Vacuum just stopped working
Should be under warranty. Take it to a warranty center for repair
Jan 05, 2014 | Eureka Mighty Mite 3670 Bagged Canister...
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
No suction or spray - Eureka Atlantis Steam Cleaner
I got the machine working. I think because it hadn't been used for awhile that the seals were dried out. I wet them and let it sit for awhile and then I could push the containers all the way in and seated them properly. Then it started working no problem and I got to clean my carpets.
Oct 05, 2009 | Eureka Atlantis 2591A Upright Steam Vacuum
New Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Jul 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
No Suction
is your brush roller turning? unplug the vacuum and see if you can turn the brushroller by hand.if it turns real freely the the belt is broke ,if its real hard to turn then something is caught up around the bearings on the ends of the roller.my suggestion is if your having that much trouble withit take it back and tell them you want a new one.if they want to keep your buisness they will give you a new one
Jan 02, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Won't work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12151&thid=646957
Won't work (by 2 users)
Posted by AndiR on Jun 04, 2008
My Eureka Mighty Mite 3670 Bagged, was working fine, and we unplugged it to switch to another outlet in another room and it just stopped. We tried several other outlets and it just won't turn on. We thought maybe it got hot because we had been using it for a while and we let it rest for a while and then changed the bag just to be sure, although it was not full. But it still will not turn on. Any ideas……X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by Guest, posted on Jun 06, 2008 I had the same problem today. Have a 9 amp model I bought 10 years ago which I never use. It has been sitting for years. Today put in new bag and ran it continuously for 45 minutes. After I turned it of it wouldn't restart. Tried another outlet and wouldn't restart. Felt canister at back and motor housing was hot so I thought I might need to let it cool down. After letting vacuum cool off for 10 minutes it restarted. All I can assume is that the vacuum has a built in overheat sensor on the motor. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka Mighty Mite #3670 Bagged Canister. I have the same type Mighty Mite Canister and from what you are saying the must be some type of heat sensor that is shutting off the motor to protect it from excessive heat. Al of the old ones have had lower amps and did not needs the heat sensor but once the bag is full and the filter clogged; they will shut down as well. They all use a plastic hose to clean with and that even gets hot sometimes. So I suggest that you get an owner’s manual from the manufacturer on you particular model so that id if happens again, you will be prepared. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
5855 Terry Fox Way
Mississauga, Ontario L5V 3E4
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Eureka Mighty Mite 3670 Bagged Canister...
Eureka Mighty Mite 3670 Bagged Canister Vacuum Logo
293 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
