Question about Health & Beauty
FBC FBZ MBW ELFT EPO
POLYCYTHAEMIA
Who is MBW ASO Wireless and why are they taking money from my account?
fixya doesnt have access to your or other company accounts need to notify MBW ASO Wireless and inquire about the account in your name and same with your bank
Oct 29, 2016 | Computers & Internet
Where is the flasher located on a 2000 Hyundai
its mounted under stering column need to remove the lower instrument panel cover and you see the flashet on the elft
Oct 07, 2014 | Cars & Trucks
How can I download the driver for the DVD-8216?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if you physically unplug your cd/dvd restart your computer the plug it back in the found new hardware wizard should activate
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps
Jul 28, 2012 | EPO Technology EPO DVD 8216 (DVD-8216)...
We have a MGE 30KVA. It experienced a crash of some sort. The technicians say the EPO button was pushed, but it wasn't I was the only one in the server room at the time, Anybody have something similar...
Ask the IT guys to print the UPS alarm history for you.... if the EPO was pressed then it will be recorded in the history.
Once you have the history it may be possible to work out what has happened
Thanks for using FixYa
Jan 04, 2011 | Computers & Internet
Just restarted a 9339-40 ups after moving it to another bldg. And it has no output now. Screen says epo needs reset. Any help?
Most follow the reset procedures to reset from a EPO shutdown. Usually it is a fuse on Powerware that needs to be pushed back in.
May 19, 2010 | Powerware 9330 40 (A40401110031112) UPS...
How do I replace drivebelt on sankyo dualux 1000 projector
Inside parts:
Small belt wheel (SBW)
Large belt wheel (LBW)
Motor Assembly (MA)
Fan Blades (FB)
Fan Blade Cover (FBC)
Make sure you have magnetic screwdrivers.
Remove MA - 4 screws.
Remove FBC - three screws
Loosen LBW and slide down shaft a small bit away from end. Need small Allen wrench.
Slip new belt around LBW (takes some fiddling).
Put LBW back to previous local and tighten.
Reattach FBC.
Put motor in place.
Stretch belt over FB and onto SBW. (It will make it.)
Screw in motor.
Good luck.
Feb 21, 2010 | Photography
I can not find my Worldbook drive on the network sometimes it's there and sometimes it's not there. I am running Windows 7
Are you using it with or without Mionet?
If you have the MBW blue rings version it may be a compatibility issue.
NB: only do this if you're not using mionet! (this is for MBW Blue Rings)
If the drive worked without problems for a period of, perhaps you could try resetting it (this will reset the drive to DHCP - If you had it set to static before and the login details will be default again username: admin | password: 123456). Your data will not be effected by the reset
Reset for MBW White Light: (refer to the link for reset prosses using mionet in the last link)
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3553&p_created=1241119153&p_sid=lnbHW1Tj&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NjgsNjgmcF9wcm9kcz0yMjgsMjA5LDI2MyZwX2NhdHM9MCZwX3B2PTMuMjYzJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfZm5sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9cmVzZXQgbXkgYm9vayB3b3JsZCB3aGl0ZSBsaWdodA!!&p_li=&p_topview=1
If you are using Mionet, refer to this link for instructions:
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=3262&p_created=1231875761&p_sid=lnbHW1Tj&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAsMTAmcF9wcm9kcz0yMjgsMjA5LDIyMSZwX2NhdHM9JnBfcHY9My4yMjEmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yZXNldA!!&p_li=&p_topview=1
Hope this helps!
Nov 10, 2009 | Western Digital My Book World Edition 1TB...
The door will not open
maybe the cd is stuck, or the dvd driver is broken.
take a small paper clip and put it in the front little hole and push.
then the drive gonna get out manually.
Jul 09, 2009 | EPO Technology EPO DVD 8216 (DVD-8216)...
Mc cafee ePO management version 4.0
Hello jsnikhal,
If you are running Windows Vista, here is a good article that may help lead you a sulotion: Installing McAfee ePO Common Management Agent (CMA) on Windows Vista - http://neverblog.net/installing-mcafee-epo-common-management-agent-cma-on-windows-vista/
I hope this helps. If it does then please rate this solution.
Have a great day,
martyshaw152
Mar 21, 2009 | Compaq Computers & Internet
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
