Question about Vissani MCWC50DST Wine Cooler
Temp shows EEF - Vissani MCWC50DST Wine Cooler
What is the problem when spa temp showing 100 and actual temp is 90
see if you can calibrate temp if not replace temp sensor
May 23, 2016 | Pool & Spa
Ambient outside air temp sensor
i may be wrong but that sensor is for the ac not for engine operation and at 113 if its not that hot then the sensor is bad but if its summer its ok,, your engine works with intake air temp
Nov 25, 2013 | 1996 Jeep Cherokee
My water temp keeps showing 197 or higher temp. The air temp shows the correct temp
You need a new water temp sensor. This is an extremely common problem with the RS system.
Oct 21, 2013 | Jandy AQUALINK RS TELELINK KIT
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
05 GMC shows wrong temp. for out side temp. on
Ensure that your Outside Temp Sensor is in the correct place, installed near the radiator on the lower portion of the vehicle, under the hood.
Check/replace if broken or damaged.
Dec 26, 2009 | 2002 Chevrolet TrailBlazer
Tried resetting the thermostat. Shows 70 degrees for a second. Then back to 78.5 degrees. When I use the arrow adjust to change settings the number does not change
Depends on your Tstat. The set point is different from room temp. My tsat show set point and room temp. But to answer you when you set at 72 and room temp is 75 . It will go back to room temp till you reach that temp. Rusty
Jun 07, 2009 | Heating & Cooling
Vissani MCWC50DST Wine Cooler Logo
52 people viewed this question
Top Vissani Furniture Experts
Jay Finke
Jay Finke
ray gallant
L Pfaff
L Pfaff
Are you a Vissani Furniture Expert? Answer questions, earn points and help others
