Question about Greenlee 755 High-Pressure Hydraulic Hand Pump
Low fluid how to fill the fluid ??
94 Oldsmobile 88 breaks go to the floor
Loss of brake fluid. Possible bad brake master cylinder
Jan 04, 2017 | Oldsmobile Cars & Trucks
2004 olds alero transmission fluid how much to fill up
fill it to just above the low level , check it while it is running, (in park) ;-) on a level surface. drive it around the block to warm up the trans, check it again, if it is still low then add some to the full line, check again while running. (don't add fluid when running) it should stay at the full mark at this point.
Apr 05, 2013 | 1999 Oldsmobile Alero
2012 windshield washer fluid low light came on but when I filled the fluid the light did not go out
A 2012 should be under warranty . These cars have to be scanned when lights come on usually because of their computers. It could be as simple as a reset, but I would take it to the dealer, or try running the fluid low purposely, and filling it up again as they may have a float inside the washer resevior sticking, Toyota is good to fix their customers up, if all else fails, I would bring it in. Hope this was helpful
Jan 02, 2013 | Toyota Camry Cars & Trucks
Engine management light on suspect gearbox fluid low, don't know where to fill up
chances are it no filler or dipstick making it a dealer only special tools type job
May 19, 2012 | Mitsubishi Spacewagon Cars & Trucks
97 Nissan Maxima. Where do I fill Transmission Fluid?
That is were you fill it up but you will have to get a funnel to do so.
May 11, 2010 | 1997 Nissan Maxima
Brake fluid low. how do i top it up? the tank is a weird shape.
Open the brake fluid reservoir and fill to the fill line. Be aware though that this is indicative of a leak somewhere. If it's low again you need to start looking for where the leak is. Also make sure you check the fluid levels on even ground for you vehicle. Good luck!
Jan 20, 2010 | 2005 Dodge Caravan
Brakes mushy, fluid a little bit low, but filled
if you can not find a leak then try to bleed your brakes somtimes thell loose pressure but if your fluid goes low then you most likey have a leak the smallest hole anywhere in the brake system will cause this
Jul 09, 2009 | 1994 Pontiac Bonneville
Transmission light on, but no problems with the transmission, is the fluid low?
Hard to know. You fill it to the fill mark. If it is 2 quarts low, put 2 quarts in it. 1 pint, add 1 pint.
May 29, 2009 | 2002 Dodge Durango
Low transmission fluid
Easy....you have to get under the car and remove the filler plug ABOVE the drain plug. You fill it till it comes out of that hole. You have what is called a closed cased transmission. Filling your transmission is very similar to filling a rear differential case.
Hope this helps!
Mar 30, 2009 | 2000 Pontiac Grand Am GT
Greenlee 755 High-Pressure Hydraulic Hand Pump Logo
Top Greenlee Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Greenlee Plumbing Expert? Answer questions, earn points and help others
