Question about Lowrance Elite-5 HDI with 83 200 kHz and 455 800 kHz Transducer
How do you get off demo mode on my elite 5
Trying to remove the demo mode from unit. What do I have to do?
How do i turn the demo mode off of my Kenmore Elite freezer
On one model you do the following: To get it out of the demo mode, press and hold the "up" and "set" pad for 10 seconds.
Feb 10, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
How to get out of demo mode
Press Menu Twice
Scroll down to Simulator
Press Enter
Take Blue Blob out of simulator selection
Nov 23, 2014 | Lowrance Elite-5 HDI 83/200 455/800 Combo...
Cant get the demo mode off my lowrance elite 5 dsi
go to menu click on system find simulator mode click off
Sep 21, 2012 | Lowrance Elite-5 DSI Color Combo...
My Archos 101 has a demo version and goes into demo-mode every 5 minutes. Any way I can remove this 'obstacle'?
1. You can press the RESET button by inserting the end of a paper clip into the hole underneath the device (to the left of the USB cable connector).
Note that it won't erase any data, it will just restart the device as if it was a computer.
2. Press the power button as usual to turn on the unit.
Do not press any buttons, the screen will still display the demo mode for about 20 seconds and then it will go back to normal display mode.
Jun 04, 2011 | Computers & Internet
Turn demo mode off on Sony Bravia TV
Press and HOLD (5 sec) the MENU button located on the SIDE of the TV. A message will appear; (Demo Mode: OFF).
Mar 30, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
Just bought a kenmore elite bottom freezer trio model and display panel shows o ff. Expect this means whole unit is off but manual does not say how to turn ON in the setting the controls section of manual....
I just purchased a similar model and had the same frustration. Finally called the store and it was in DEMO mode. Open the freezer draw and hold down the Ultra Ice & Refrigerator Temp buttons simultaneously for 5 seconds. That worked for me and hope it will do the trick for you.
Jul 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Demo mode
on my sportster 5 I held down Menu and Display together for 5 seconds to unlock the demo mode
Apr 09, 2008 | Kenwood KDC-MP335 CD Player
Cant turn off the demo mode
There is often confusion in the way the manual states how to achieve removing demo mode. Because this is listed in the "Menu System" section of the manual and assumes you read from page 1 of the manual that you will know to enter the menu in this section of the manual. Here is step by step instructions on removing demo mode on your unit. 1. Go to standby mode 2. Press and hold the menu button till the menu comes up 3. Press control knob towards AM or FM to scroll through menu till you locate "Demo On" 4. Press control knob straight in for approximately 3 seconds till it switches to "Demo Off" 5. Hit menu button again to exit menu
Apr 05, 2007 | Kenwood KDC-MP732 CD Player
Kenwood demo prob...still
Feb 18, 2007 | Kenwood KDC-MP232 CD Player
Lowrance Elite-5 HDI with 83 200 kHz and 455 800 kHz Transducer Logo
405 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
